A/C Pump stays running when A/C is off
I have a 1983 Short bed Scottsdale. Its a 4 speed 4x4.
It used to be a 250l4 now it has a 350v8. As the title states, it stays running even though the switch is off. Another weird thing is if I have the blower fan running and turn the truck off, it stays running for about 3 seconds after the ignition is off. I have to unplug the AC pump because it will run the battery down. any idea why thats happening? Last edited by bradford; 06-08-2011 at 07:01 AM. |
Insert Witty Text Here
Re: A/C Pump stays running when A/C is off
My compressor was running pretty much all the time when the truck was running. I replaced the dash controls with a set of new ones, and the problem went away. I can't say for sure that is what is wrong with yours, but it solved my problem.
Slonaker |
#3 | |
Seems odd that the inside switches were making the battery ground terminal melt. You would think that the wires on the inside of the truck would melt first. Thanks. |
Electricity always takes the path of least resistance, hence the battery ground.
