Old 06-08-2011, 07:53 AM   #1
chevyman95
chevyman95's Avatar
question before I rebuild my carb
I have a 454 in my truck with a holley double pumper carb. It sat for a while but I recently got it running but it accelerates horribly under throttle and if I even blip the throttle it will cut out. I am assuming this is because the carb has sat and got gummed up. Is there anything else that might cause this? Thanks
chevyman95 is offline   Reply With Quote
Old 06-08-2011, 09:14 AM   #2
geezer#99
geezer#99's Avatar
Re: question before I rebuild my carb
Retarded timing also causes that. What distributor? What's your timing set at.?
Old 06-08-2011, 09:23 AM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Does it hesitate or just run rough under acceleration? Could possibly be the accelerator pump diaphragm. They will dry out and crack if they sit for a while with no fuel in the bowls. BTW, yours will have 2 of them if it's a double pumper.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-13-2011, 09:55 AM   #4
chevyman95
chevyman95's Avatar
It was this, I rebuilt the carb and the old accelerator pumps looked pretty bad. Runs like a champ now, Thanks for the advice
Old 06-13-2011, 12:45 PM   #5
70STOVEBOLT
No problem, glad to hear you got it fixed.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
