06-08-2011, 10:27 AM | #1 |
67 truck... what sparkplugs you guys running?
Okay well I am finally getting my 67 truck road worthy.. My issue is that its been sitting for years..it actually drive decent but I was planning on replacing some of the stuff I dont know the history of. right now I hit the gas and there is a lag before i actually go anywhere. Not bad but a little.. I assume i need the carb adjusted some but my thought is that I would replace the plugs and wires.
Truck is as follows. 1967 chevy c10 shortbed. 350 engine HEI with TH-350 trans. 600 Edlebrock carb No cam that I know of. I will be adding Headman headers and Edelbrock intake. Nothing crazy just a cruiser. Also what engine oil do you guys run? Synthetic or what? I am the do it right type person so I just want to make sure to get this thing mechanically sound so I can engine it. any help for a rookie would be appreciated.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
06-08-2011, 11:04 AM | #2 |
So,, what else you got???
Re: 67 truck... what sparkplugs you guys running?
Hey there. You can't go wrong with a good set of AC Delco or Autolite plugs, not a big fan of the gimmick plugs. Also check your vaccum advance on the distributor to see if it is cracked/blown. Synthetic oil is priced right around here, almost the same as conventional oil. Good luck with your truck, enjoy it and don't try to overthink everything.
06-08-2011, 12:11 PM | #3 | |
Mobil 1 synthetic for oil |
06-08-2011, 02:04 PM | #4 |
What weight are you running for oil? I might pick up those plugs tonight. Thanks
I also will check the vaccum advance thanks guys.. Learning as I go.
06-08-2011, 05:30 PM | #5 |
I run plain autolite plugs and conventional oil then use a zinc additive to help protect my cam. Most of this new oil and plugs is definitely a gimmick to me.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
06-08-2011, 05:52 PM | #6 |
06-08-2011, 05:56 PM | #7 |
I know its wierd but I tried Bosch DP plugs and a new set of Belden wires and Im getting some of the best ignition Ive ever had. Delco plugs are made by NGK, so save some $ if thats the way you want to roll.
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars |
06-08-2011, 06:17 PM | #8 |
Delcos, all the way!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
