![]() Join Date: May 2011
Aftermarket tach mounting
Trying to decide where to put mine. Its a 3 3/4 Autometer. Was gonna put it on the column but I think it may block the speedo and gas gauge. Where is everybody mounting theres.
Slugish
![]() Join Date: Jan 2005
Re: Aftermarket tach mounting
Put mine here
Ya but what did you do with the fuel gauge?
Posted via Mobile Device |
78K & 79C Jimmys
a little more to the right if your not using the AC
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Slugish
I put mine on the steering colum, from the photos it looks like its in the way but i have had it there for about a year and its never been in the way.
That smaller tach looks sweet - what bulbs do you have in there? I like how well lit it is.
#8 | |
Foom, foom, foom!
![]() Join Date: Mar 2005
Has anyone done this?
- Dan 84' LWB C10 // 2.5" from collector back. duel Turbo Mufflers // 350 w/ TH350 long Headers//3.73 rearend gears Future Mods 3/4 suspension drop ![]() |
I attached mine underneath the radio/ashtray.
Mine was put in be the p.o. and he put it on top the dash next to the pillar on the drivers side. I like the placement of it. It's not in the way of other gauges and it's visible looking out the windshield w/o being in the way either. These are the best pictures I have showing it. One from the outside and inside.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
bottom left:
and a pic at night:
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
Getcha Pull
"Back in the day" my truck was setup with a 5" Autometer with shift light strapped to the column covering the fuel level gauge. The fuel gauge could be checked by a simple lean to the left, and you had a easy to see tach. Which was the speedo for a while because the real speedometer was broken, and there was also that time the fuel gauge was broken anyway lol.
Sorry, no pictures. I'm a huge fan of that spot though, and since I could see the fuel gauge with the 5", the 3.75" will be fine. Your gauge will be low, and the fuel needle is near the top. ![]()
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
#13 |
Well I put it on the column. Doesn't seem to block the speedo and fuel gauge too bad.
#14 |
#15 |
#16 |
78K & 79C Jimmys
somebody set the tach on the coloum
and it slid into the middle when in drive
#17 |
![]() how i have mine done. makes my truck look mean as hell from the outside lol.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
#18 |
Kikkegek: What lights are you using in your dash??
#19 |
its an RGB SMD strip. Normally you get in each light point Red,Yellow and Blue. But I got a strip with three whites. And I choose a soft tint of white. So it looks normal and is easy on the eyes at night.
look on ebay for "rgb warm white led strip" http://cgi.ebay.com/1m-LED-STRIP-505...item3a64df37c4
#20 |
![]() ![]() Join Date: Jul 2002
The prior owner mounted the tach here on my 83.
I cleaned up his wiring mess, but for now I am going to leave it where it is.
#21 |
Heres a couple more pics. And 1 you can see how I trimmed the hose clamp to clear the turn signal lever assembly. I was worried it may weaken the hose clamp but it ended up working out. I can't tilt my steering wheel all the way up though as it hits the tach mounting bracket but it'll go up a coupe notches.
#23 |
#24 |
Its a 3rd gen camaro tach. Check his build thread in his sig or these:
http://67-72chevytrucks.com/vboard/s...ht=camaro+tach http://67-72chevytrucks.com/vboard/s...ht=camaro+tach http://67-72chevytrucks.com/vboard/s...ht=camaro+tach
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#25 |
Charlie Daniels w/ a Tq Wrench
I mounted mine on the column, but used a smaller 2-5/8 tach so it does not obstruct the other gauges. I think it fit and matched nicely.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
