Old 06-08-2011, 04:31 PM   #1
ADub
Accessories
I will be swapping in an LS motor eventually. I've been casually looking for good deals on 6.0s as Im not really near the engine stage of my build yet. Most of the engine's I'm running across at local yards come without front accessories.
Are most of you guys using the truck engine accessories? Are there any accessory packages that don't fit?
69 C10 SWB LY6 T56
70 Chevelle SS 396 4spd
ADub is offline   Reply With Quote
Old 06-08-2011, 06:19 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Accessories
with a truck intake, you use truck accessories, with a car intake you use car accessories, they wont interchange, also corvette accessories is also different from the car accessories.
If you get a "pull out" motor, ask for the accessories too, it will definitely be cheaper from the recyclers than new.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-08-2011, 06:33 PM   #3
ADub
Re: Accessories
Sorry, I should have mentioned that Im running a carb, so intake is no issue.
So both car and truck accessories fit?
69 C10 SWB LY6 T56
Old 06-08-2011, 10:01 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Accessories
Fit in terms of bolt on, yes. Like they said the intake situation changes it, but with a carb it takes that out of the picture.
You may want to also consider WHERE each type of accessories place the components. You wouldn't want to buy an accessory setup and then find out he alternator location doesn't work with the space you have.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-08-2011, 10:14 PM   #5
ADub
Re: Accessories
I understand the accessories are interchangeable between the engines (except VVT issues).
Truck is the 69 in my sig. I guess I should have been more specific in my post. Are either style of accessories going to fit between the frame rails? That would be the only area of clashing on a 69 C10 right?
69 C10 SWB LY6 T56
Old 06-09-2011, 09:49 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Accessories
I'm pretty sure the 69 is similar enough to the frame of my 66 for comparison; the truck accessories fit just fine in between the rails (I have no a/c), but I did put a little "tweak" in the frame rail for the power steering pulley clearance.
Old 06-09-2011, 09:51 AM   #7
Shon
Re: Accessories
They will interchange but not without effort.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-09-2011, 12:06 PM   #8
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Accessories
I purchased a long block LQ4 with only an intake on it. However, I found a salvage yard that sold me all the Brackets, DBC Throttle Body, AC compressor, PS pump, Coil Pacs and brackets, Various bolts and etc for $300. I decided to get a new water pump in this case. I think the price was more than fair? Thoughts?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 06-09-2011, 12:41 PM   #9
Clyde65
Clyde65's Avatar
Re: Accessories
sounds good to me, compressor/alt and PS pump rebuilt will be probably 2.5 times that anyway. even if something is bad you will have a core. Smart move on the WP.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-09-2011, 02:12 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Accessories
My motor is carb'd too. It came with just the truck accessory bracket, the water pump, water pump pulley, and crank pulley. Since my motor was new, I decided to buy all new alt., p.s.pump, and idler pulley. Got most of it thru rock auto.
which intake are you using? I wound up with a GMPP LSX dual plane, made for L92/LS3 style heads.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-10-2011, 01:55 PM   #11
ADub
Re: Accessories
Haven't decided on the intake yet, been waiting until I buy an engine
69 C10 SWB LY6 T56
