Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-08-2011, 05:06 PM   #1
RICKSRAT
RICKSRAT's Avatar
New Track times
Well finally got the Truck to the track for some test and tune. Ran on motor only on 93 pump gas. Nitrous fuel regulator was acting weird so didnt want to spray it.
Had a few minor problems but in all went well.Weather was a bit warm mid 90's. Track scale was not open so didnt get a new weight on truck. Should be around 3,600-3,700# no driver. Had convertor tightened for N2 and was stalling at 4,000 from previous 4,500 last outing.So this time out ran close to the previous best motor pass(10.79 @120.9) with stall change.Was turning 6,000 @ the traps so with N2 should put me around 6,800-7,000. Other changes were 4.10 12 bolt truck rearend to 4.30 Moser Dana 60.
Main problem was not transfering weight well with the 1" drop springs,which I was expecting. Called Santhuff to order new 250# front springs to get the weight transfer and 60ft down.
Made 5 passes total and 2 best are:
60' - 1.53 / 1.56
330' - 4.40 / 4.47
1/8 - 6.85 / 6.92
MPH - 99.59 / 99.74
1,000 - 9.01 / 9.08
ET - 10.86 / 10.94
MPH - 120.75 / 120.26
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 06-08-2011, 06:55 PM   #2
ripdog28
ripdog28's Avatar
Re: New Track times
Bad @$$..... What is your rear suspension setup? Coilovers? Also elaborate on the engine...
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-09-2011, 08:18 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: New Track times
Man that sucker gets out of the hole awesome, that's an outstanding ET for 120mph. How much are you going to hit it with?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 06-09-2011, 10:00 AM   #4
nomrlz
nomrlz's Avatar
Re: New Track times
nice runs. i noticed your second run had more mph at the 1/8 but less at the 1/4. this has always puzzled me with my cars or bikes. it seems to happen a lot with my stuff
nomrlz is offline   Reply With Quote
Old 06-09-2011, 10:10 PM   #5
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Rear suspension has 36" Chassisworks double adjustable ladder bars w/ 14" Strange single adjust coil overs.
Motor is a 534" 10.5:1 with GMPP 290 oval port heads.Heads were fully ported by Mike Stark @ CFM performance. Comp solid roller.Victor Jr 4500 w/ Holley 1050HP. Motor Dynoed @ 721hp / 677tq on 93 octane.
Looking to Spray the N2 up to 350hp ish , 200 +/- out of the hole and add the second stage probable on a timer.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 06-19-2011, 11:06 AM   #6
shawnt
shawnt's Avatar
Re: New Track times
Mike does some NICE work!
Good runs and MPH, definately more in it on motor alone
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 10-07-2012, 06:37 PM   #7
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Finally got back to the track to make some nitrous passes. First pass ran a 10.70 @ 123 on motor w/ 93 octane. I had made a rear spring change 200# -> 150# to check it out. Got a gopro video and another video of 2nd nitrous pass. Put some VP C-12 and turned the bottle on. Pass was 1.35 60' and 9.82 @ 133.6 on 1 stage w/225 shot . Guy in other lane lit both bulbs and when I rolled in and starter didn't give me much time to load up the convertor. Also 1st pass I pulled 2nd gear real early. So I made sure I didnt 2nd pass as you see in video. Was right at 7,000 crossing the line so convertor and gear seem to be ok. Also scales were open and was 3,820# w/driver. Now ready to finish wiring up the second stage and see what it will do.
http://youtu.be/R0Wf_8NXit8
http://youtu.be/sI0qQfgYxr4
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 10-07-2012, 07:15 PM   #8
shawnt
shawnt's Avatar
Re: New Track times
Nice job!
What was the 660'? Im assumin 6.20's or high teens? Thats getting it done!
Shawn
85 SWB
7.39 @ 93
Old 10-08-2012, 06:38 PM   #9
scatesracing
Machinist
scatesracing's Avatar
Re: New Track times
Do you think the spring change in the rear helped... and did you get the springs changed to to the 250# ?
scatesracing is offline   Reply With Quote
Old 10-08-2012, 07:01 PM   #10
shortbed70
shortbed70's Avatar
Re: New Track times
Yea buddy that thing leaves hard, nice job!!! Might want to put some Velcro on that bed mat lol...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-08-2012, 07:14 PM   #11
Marv D
Registered Truck Offender
Marv D's Avatar
Re: New Track times
That much weight into the high 9's is some SERIOUS hauling bootie. Congrats on a job well done.
BTW, what is the popping at the top of 1st gear? Too much timing on the hose, not enough octane, rev limiter??? Any kind of misfire/ scatter and N2o would scare me to death.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-09-2012, 07:47 AM   #12
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Shawn yes 6.20 on the 330' . Had the truck out a few weeks earlier with the 200# springs and the rear just would not move , so went to a 150#. Marv yes diffently the rev limiter . This was the 2nd nitrous pass , the 1st pass I pulled 2nd gear real early and didn't want to do the same again. I have the transbrake button on the shifter and as soon as I let transbrake button off I pulled the shifter on 1st nitrous pass.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 10-09-2012, 08:52 AM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New Track times
Stay off the rev limiter on the spray . Nice passes . Next time im out and see you ill stop by and say hi . You know David Sheetz ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-09-2012, 11:29 AM   #14
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Hey Hotrod yes not a good thing on the rev limiter. Its been about 8 years since i've sprayed the truck so driver is a little rusty. Ans yes come by next time. Will be going again in a few weeks maybe we can meetup. May go to Sealy next time Baytown isn't what it use to be. No don't know David where is he from?
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 10-09-2012, 12:12 PM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New Track times
Not trying to hi jack , but friday night they dont prep much and it is pretty much street car night . I will come by and say hi .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-09-2012, 12:27 PM   #16
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Hotrod yea thats what it looked like,but was only night I could go. Website says they are only open on Friday nights. Didn't they use to open on Sundays before and more of a race car crowd. Also Question .. since when do they not top a nitrous bottle off.... Guy filling bottles at the track said he could only fill an empty bottle... um b.s. They have a pump AND cool it off in an ice chest to fill the bottles. At 5$ a pound kinda sux to empty a bottle with 3-4 # left in it.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 10-09-2012, 12:31 PM   #17
egaray281
egaray281's Avatar
Re: New Track times
so is the time of the year when people start going outthere to baytown?
egaray281 is offline   Reply With Quote
Old 10-09-2012, 06:57 PM   #18
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New Track times
They are no longer open on sundays . Friday night if you want to get some passes in be there early and get the passes in by 8 then leave , as it gets crowded after that and things slow down .
Yes , you are correct the new policy is to not fill a half full bottle . They are just trying to get every drop out of the mother bottles and dont have the valve arrangements to save what is in the line . $5 Lbs is what they charge . I took them an empty that i had pulled a vacuum on , i explained it to him , had it marked on blue duct tape bottle in vacuum whole 9 yards . He walked it over to the bench and opened the valve . I was like you just lost that $50 cause not there is air in my bottle . I have a guy in Baytown fill mine . I drop them off he tops them off and calls me when they are done . HMP is your only sunday option .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-09-2012, 01:27 PM   #19
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Wheels up pass from Friday night at Baytown. Made a jet change (225hp 82f/82n -> 250hp 87f/92n) and dropped fuel pressure 7# -> 6 1/2#. Looks like some suspension tuning is next. Sparks are from lower control arms. Ran a 10.08 @ 127.93 w/ 1.44 60' getting off throttle and back in it.
Dinnut also made it out and helped out thanks.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 12-09-2012, 01:34 PM   #20
shortbed70
shortbed70's Avatar
Re: New Track times
Whoohooo that looked like fun!!! Probably should slow the front down some...
Troy
Big Red Dog build
Old 12-09-2012, 03:25 PM   #21
Super73
Super73's Avatar
Re: New Track times
Nice ET.. Definately more in it.
I don't remember what you have for rear suspension. Is it a 4link, ladder bar or stock style trailing arm.
If tightening the front shocks isn't enough, you might be able to add more antisquat by raising your instant center of gravity. More antisquat = less front lift.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-10-2012, 01:11 AM   #22
dinnut
dinnut's Avatar
Re: New Track times
Good to help you out! Hopefully next time out ill have my motor back in from the machine shop and shootin' for some better times. I think your truck has more in it on motor. Definitely impressive...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-11-2012, 04:49 PM   #23
RICKSRAT
RICKSRAT's Avatar
Re: New Track times
Super73 , Truck has 36" Chassisworks double adjustable ladderbars w/ Strange egineering single adjustable coilovers w/150# 12" spring. Front springs are from Coil Spring Specialties custom built @ 455# and 14 1/4" length w/ a .660 dia. Shocks are Comp engineering 3 way adjustable C-2615 for our trucks set @ 90/10. Plans are to go double adjustable on back and 80/20 Adjustment on fronts. Really want to go to a Scotts or Nolimt front end to reduce weight. So staying with the cheap Comps until I decide if I want to stick with stock crossmember or not.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 12-11-2012, 04:57 PM   #24
Super73
Super73's Avatar
Re: New Track times
With how fast that front is coming up, I bet the 70/30 setting in front would be better than the 80/20.
How tight are the rear shocks? Have you tried putting a zip tie on the shocks shaft to see how far they are compressing or extending under launch? Might help to tell you if you should loosen/tighten the shock.
What is the ICG height currently set to? Perhaps try moving it up 1 hole and see if it slows front rise down at all.
I personally would try those things (if you havent already) before spending money on a double adjustable (not saying you won't benefit at some point).
Old 12-12-2012, 10:54 AM   #25
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New Track times
Wow . what a ride ! Good air last friday . DA was like -300 . Truck sounds strong . Congrats on the 10.0
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
