Old 06-08-2011, 05:26 PM   #1
dishow
dishow's Avatar
seat bracket question.
hi. will a driver side and passenger side seat track interchange? i know one pulls to the left,the other the right,but can you swap them around? i have pass side 60 and driver 40 bases. can i use these bases to make one passenger side bucket base? outer bases of each? makes sence, just want to ask first.
90 Chevy 454 ss
Old 06-08-2011, 06:07 PM   #2
dragginmetal
here, just not logged in
dragginmetal's Avatar
Re: seat bracket question.
Yes, the outer bases will work to make a 40 but it will have 2 handles . If you have all the bases to a 60/40 you could just use both of the 40 bases on the pass. side. Its the inner base on the 60 thats at a different angle, since it bolts to the trans. tunnel.
dragginmetal is offline   Reply With Quote
Old 06-08-2011, 09:11 PM   #3
dishow
dishow's Avatar
Ok got ya.I should have mentioned its out of a93 so the 40 is on the drivers side
90 Chevy 454 ss
Old 06-08-2011, 09:54 PM   #4
dragginmetal
The driver side 40 will bolt to the pass side. Only difference will be, you will pull the handle to the inside to move the seat forward and back. Where stock passenger side normally pulls to the outside. Hope i didnt confuse you.......... The bases for the 40 will bolt to either side... If the holes are allready in the floor. If not you will have to drill the inside holes on the pass side.
Old 06-08-2011, 10:23 PM   #5
kevhill85
91 SWB 383
kevhill85's Avatar
I see this done in s-10 alot
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 06-08-2011, 10:41 PM   #6
dishow
dishow's Avatar
Ok great.just to clarify, a bucket base is the same as a 40 ?
A bucket base is what I need.
90 Chevy 454 ss
Old 06-08-2011, 10:42 PM   #7
benoit454
Chris
benoit454's Avatar
you can also use bench brackets to bolt up buckets, I've done that on the 85 monte carlo ss I had and saw it done on these trucks too.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-08-2011, 11:20 PM   #8
dragginmetal
Yes.
Old 06-09-2011, 12:39 AM   #9
dishow
dishow's Avatar
Thanks.this forum is great
90 Chevy 454 ss
Old 06-09-2011, 02:05 AM   #10
89chevsj
error 404
89chevsj's Avatar
yes a40 is the same as a bucket.
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
