06-08-2011, 10:14 PM | #1 |
Ls1 Brakes
I put a 1998 LS1 rear end and brakes in my 56 chevy pickup and want to use the matching front calipers on the front. Does anyone make a 12" rotor and caliper bracket for the mustang II spindle?
Need more money |
06-10-2011, 01:00 AM | #2 |
Re: Ls1 Brakes
I did a Google search and found this http://www.tffn.net/phpBB3/viewtopic.php?f=9&t=21222 I didn't check on the Master Power kit that was mentioned though.
I don't know anything about these guys but check the second listing on the page http://www.streetrodgarage.com/musta...cbrakekit.aspx http://www.google.com/search?source=...&aqi=&aql=&oq= Is the search I did. Ford makes it kind of easy in a way as they pretty well use the same wheel bearings on a lot of their vehicles. The outers are the same for almost every rear wheel drive Ford car and most of the small/ Mid size Ford products run the same inner wheel bearing and seal. That might help the rotor hunting a bit. Last edited by mr48chev; 06-10-2011 at 01:13 AM. |
