Old 06-09-2011, 07:44 AM   #1
BBrendal
Recalculating.....
BBrendal's Avatar
Top texture
Has anyone here used this stuff on their top? I really like the texture and want to use it on my top. Gator guard seems too rough for me. If someone has used this can you just paint the top with it and be done or does it need to be top coated? You can buy it in quarts as well.
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 06-09-2011, 08:03 AM   #2
4oldcars
4oldcars's Avatar
Re: Top texture
I was gonna try bed liner. Note I said try.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 06-09-2011, 03:50 PM   #3
BBrendal
Recalculating.....
BBrendal's Avatar
Re: Top texture
Im not liking any results with bedliner either. This stone guard stuff was posted on a previous thread (I cant find) and I saved the pic from it. Wish I knew who posted it. Here is a pic of the stuff on a top.
Iwish I knew who posted it so I could ask if it needs to be top coated or how it holds up.
Brian - (BBrendal)
Old 06-09-2011, 04:06 PM   #4
Bentblazer
Bentblazer's Avatar
Re: Top texture
You might check with the manufacture if a tint can be added to the mix which would take less time as a all in one job, that is what I did with my bedliner for my top here's a pic
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 06-09-2011, 09:44 PM   #5
1949gmc
Re: Top texture
Member BobbyK has a picture scrapbook located here, Repainting Factory Blazer Top, that might help you. If I read his captions correctly, he did a bedliner first, then after a year he repainted because the bedliner began to discolor. Check it out and see if it helps. Check out his other Blazer related pictures, too. Very cool stuff.
1949gmc is offline   Reply With Quote
Old 06-10-2011, 03:57 PM   #6
Team
Re: Top texture
Brian, i used the stone guard and posted those pics. worked great for me, you need to be careful as you spray because the texture changes to larger blotches as the can nears empty, i would stop spraying when the can in 3/4 empty. I put a top coat on mine (not positive it needed one) and it is holding up very well.
Team is offline   Reply With Quote
Old 06-11-2011, 02:58 PM   #7
BBrendal
Recalculating.....
BBrendal's Avatar
Re: Top texture
Team thanks for the reply. PM sent!
Brian - (BBrendal)
