Old 06-09-2011, 02:16 PM   #1
papa's_68
th350 to sm465 trans
I have a 71 K20 with the th350 trans and I am going to put the sm465 4 speed in it. Will I need a different crossmember or anything else chassis wise to make the swap?
papa's_68 is offline   Reply With Quote
Old 06-09-2011, 06:27 PM   #2
6T8
Active Member
Re: th350 to sm465 trans
Same crossmember because it bolts to the adapter. Might have to move crossmember fwd or back. If so may have driveshafts to shorten or lengthen. Need z-bar and bracket on frame. Your hump cover holes may need to be changed. I just replaced 3 speed/rockwell setup with 4-speed/205 in my 68 panel. had to move crossmember back 2 1/2 inches. Good luck........Rick
6T8 is offline   Reply With Quote
