![]() Join Date: Feb 2011
C20 Rear Wheel Bearings
I am getting ready to take a long trip in my truck and have a question about the wheel bearings.
In a 3/4 ton 8 lug 4:10 rearend do the bearings need to be packed or are they lubricated by the differential fluid?
1971 C20 Longhorn Custom Camper |
member #16
![]() Join Date: Dec 1999
Re: C20 Rear Wheel Bearings
Yes they are lubricated by the diff fluid.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Awesome! Thanks.
Where you going? My 3/4 with Dana 60 made it to Tonopah, Az. from Arkansas fine towing a travel trailer from Arkansas. All I did to it was replace pinion seal and new Synthetic lube. Make sure it doesn't have any leaks and new topped off lube. Good luck with yours. Jim.
I am going from Prescott, AZ to Chico, Ca. I will be towing a trailer. The rearend leaks where the driveshaft is connected, but I am going to top it off before I leave. I run royal purple synthetic lube.
