Old 06-10-2011, 01:48 AM   #1
72 GMC Longstep
72 GMC Longstep's Avatar
Factory Jack Handle Help!
I am trying to put the jack handle back into its original location in the passenger side cab corner. It is a survivor 1972 GMC C2500 Longstep. I was told it goes up inside the pillar and then drops down. I have the original foam bag and the lug wrench. There is also a clip in the cab corner as well. Anybody have some guidance on this? Also was the jack wrapped in foam as well. There was another piece of the same foam that the handle goes in stuff in the cab corner. Was this for the jack? Any help would be appreciated.
72 GMC Longstep is offline   Reply With Quote
Old 06-10-2011, 01:57 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Factory Jack Handle Help!
Jack should go on the floor with a long spring and a clip to hold it down. Jack handle and breaker bar in the bag held by the spring piece that's screwed into the pillar.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-10-2011, 08:56 AM   #3
72 GMC Longstep
I can't seem to get it in the pillar, it doesn't go in either way. Is there a trick to it? I tried putting it in the bottom then into the pillar and the other way.
Old 06-10-2011, 04:09 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Maybe someone else can help as I've actually never installed a set I've seen pictures. The spring should be able to move out a bit...
Old 06-10-2011, 04:23 PM   #5
72 GMC Longstep
The spring part is no problem. The handle appears to be too long. I was told by someone else that it is difficult to get it back in, but so far I have had no luck with it. Thanksfor the reply, hopefully someone else can help
Old 06-10-2011, 05:19 PM   #6
Steve Hafner
Steve Hafner's Avatar
The first and second picture below are from a 70 and I don't know what year the instruction sheet was in. I see what you mean, the bend in the bar will make it stick out away from the corner. Someone here will know !!!
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 06-10-2011, 07:22 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=411002
LockDoc
Leon
Old 06-10-2011, 08:47 PM   #8
72 GMC Longstep
Thanks for the replys, the pictures are very helpful. I'll give it a try again tonight.
Old 06-10-2011, 09:20 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by LockDoc View Post
thanks, that was helpful to me too
Old 06-10-2011, 11:29 PM   #10
Frkypunk70
Frkypunk70's Avatar
If anyone is looking for the spring and bracket for the jack I will gladly mail it to you. Took it out when I redid my floors and never put it back in.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 06-11-2011, 01:28 AM   #11
72 GMC Longstep
I figured it out tonight. I question whether or not the handle was ever properly installed in the cab corner. I think the top must have stuck out. The reason is there is 1.5" (deep) of seam sealer in the bottom of my cab corner(s). I drilled a 5/8" hole in the seam sealer and stuck the handle in the hole in the sealer and then I was able to get it into the upper part of the cab corner. Thanks for you help!
Old 06-11-2011, 01:47 AM   #12
72 GMC Longstep
Here is how I found the jack handle and pouch. As you can see the top is sticking outside of the pillar.
Old 06-11-2011, 06:45 AM   #13
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Thumbs up Re: Factory Jack Handle Help!
Oooh! Your truck has a posi!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
