Old 06-10-2011, 02:24 PM   #1
Frkypunk70
Frkypunk70's Avatar
Trim rear bump stops?
Hey, I have a 70 cst with a 4.5/6 drop. There is no c-notch but I did put shock relocaters and GR-2's on. I notice it does not have alot of travel till it hits the bumpstops on the rear. Should I cut an inch off them? Just wondering what you guys did. Thanks Tim
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 06-10-2011, 02:37 PM   #2
Frkypunk70
Frkypunk70's Avatar
Re: Trim rear bump stops?
Sorry I should probably clarify I have about an inch before they hit now so what would be the ideal amount? Thank You
Old 06-10-2011, 02:52 PM   #3
tubbedII
needs more $$$
tubbedII's Avatar
I didn't have any bump stops in at all with my 4/6. I bottomed out on the frame twice on big bumps though...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 06-10-2011, 07:19 PM   #4
doosekoop
Thats a good question , how much travel should one expect from a decent suspension and how much bump stop is enough to prevent metal on metal contact. since we dont really haul a bunch what is ideal??
TubbedII: i would recomend at least some bump stops just to prevent metal contact which could result in cracks eventually resulting in catastrophic failure ( and we dont want that)!
doosekoop is offline   Reply With Quote
Old 06-10-2011, 09:14 PM   #5
Frkypunk70
Frkypunk70's Avatar
I'm really suprised no one has come to clarify this. Considering I did a search on it and the was'nt any info on what to do with rear bump stops. I think this would be good info for those of us without c-notches.
Old 06-11-2011, 01:10 AM   #6
ItsRandy
ItsRandy's Avatar
I trimmed mine. I now have about 1/2" pads. Didn't net much more travel but when it did bottom out it didn't sound like I was breaking parts.
ItsRandy is offline   Reply With Quote
Old 06-11-2011, 10:23 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
I usually just remove them totally.
You could start by trimming 1" off and seeing how you like it.
Keith
Convert to disc brakes.
Old 06-11-2011, 11:12 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
I agree. The factory stop is too tall. Remove it and mount a small button style stop above the axle.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-02-2011, 08:30 PM   #9
iceship
I just did my flip a few days ago....... it is about 6 or 7in...... I did the 2in drop shakle first but after the drop the shakles don't lean back like it did...... so I'm guessing I have a 6... rear end is setting right on the bump stop, have not bought any drop shocks yet...... on 2.5 spindles in front.... don't look to bad
Just alittle low in the back
iceship is offline   Reply With Quote
Old 07-02-2011, 08:31 PM   #10
iceship
O, by the way no c-notch
Old 07-03-2011, 08:04 AM   #11
LONGHAIR
There probably haven't been to many answers because it's rather subjective.
"It depends" upon what you feel is acceptable...
What are the roads like in your area?
LWB or short?
Ever carry anything?
How hard are you willing to let it "feel"?
Etc....
I wouldn't remove them totally though. Maybe cut them in half and test it?
Add a small notch?... it's not that hard to do.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-03-2011, 01:05 PM   #12
iceship
Roads are not that bad in some areas
Long wheel base
I load it once every blue moon
Id like it all to be gone but I know that is not going to happen, thinking of going with air shocks..
Old 07-03-2011, 01:34 PM   #13
19seventeeCustom
I removed mine completely, and I have hit the bed rails on the axle tube on a large dip/bump in the road.
I'm still debating a notch, just don't know if I wanna cut into the truck.....
19seventeeCustom is offline   Reply With Quote
Old 07-03-2011, 01:45 PM   #14
iceship
I had to do some cutting if I removed it completly.... that part right there has to be trimmed
Old 07-03-2011, 02:44 PM   #15
LONGHAIR
That will definitely ride bad. The only "suspension" you would have there is the sidewall of the tires themselves.......not much.
You really should do something about cutting that stop and probably notching the frame too. It's not just sitting on the stop, it's smashing into it.
Old 07-05-2011, 01:02 PM   #16
iceship
I trimed bump stop and put old shackles on....... rides better , going to get shocks some time another...
Old 07-05-2011, 02:16 PM   #17
6772owner
Gearhead
6772owner's Avatar
I have bags, no notch and I trimmed my bumpstops to about a 1/4" below the frame rail. I have never had any issues hitting the stops/frame yet, but it could be because I run the bags at 25-28 psi for my ride height. Id have to measure the clearence to my axle but I would guess its about 2" +/- at ride height.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 03-02-2016, 12:59 AM   #18
thefalconer_88
I'm having a similar issue with my 63 lwb c20 with unkown drop springs, and 2 inch blocks. I have 1" of clearance before the stop hits the axle... I guess I'll just cut them down for now. What's the best way to cut thick rubber?
thefalconer_88 is offline   Reply With Quote
Old 03-02-2016, 11:17 AM   #19
6772owner
Gearhead
6772owner's Avatar
I honestly cant remember how I cut mine, probably a sawzall or cut off wheel(?)
Old 03-02-2016, 09:30 PM   #20
VictoriaHardware
VictoriaHardware's Avatar
A band saw works perfect. Then finish with a belt sander.
VictoriaHardware is offline   Reply With Quote
Old 03-03-2016, 03:06 AM   #21
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Trim rear bump stops?
I cut mine just so they would hit the stop before the metal to metal hit. That in my mind is where you want it. You want as much travel out of it as possible without hitting under normal driving.
Take your wheels off and look into the wheel well at the bump stops and mark then just 1/8" lower than the frame. This want keep it from hitting metal to metal but it will soften the impact when it does.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
