Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-10-2011, 05:36 PM   #1
3r!c84
Badass
3r!c84's Avatar
faster time.
hey guys what can i do to run a little faster time with out going crazy like hooking a bottle up too my truck.
i already got a 400sbc/th350 3:42 posi 28inch tall tires running 13.90
pull off the tail gate?
any other idea?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-10-2011, 07:49 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: faster time.
I doubt the tailgate on / off, open or closed is going to offer much. For every 100 pounds you take off the unsprung weight you can expect about 0.10 seconds improvement. 35 pound tailgate ain't gonna offer much.
Probably the best thing that can happen to most street vehicles is go to a shop and have the motor tuned on a chassis dyno. Get a print out and pay attention to the torque curve. Then use one of the online shift calculators to set your shift points for the track. Theres a really good one on Bowlings pages (left side bottom of list). but you have to have some real world dyno numbers to get the 'real' best answer.
http://www.bgsoflex.com/auto.html
I'm going to guess running 13's that starting line traction isn't a huge issue. If it is,, stay AWAY from the water and big burnouts, and letting air out of the rear tires. Typically all 3 of those will hust 60 time with a standard street tire, not help.
Otherwise,, weight is your enemy.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-10-2011, 09:36 PM   #3
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
On run my 235/75/15 on the track. Im suprized how well they hook on the track. I cant say so well on the street. And I'm guessing the tail gate is like 80lbs it's a 84c10 btw all steal. I'll get a video and more into on the truck in a little.
-00 Saturn 5spd
1/4:13:90
Old 06-10-2011, 09:49 PM   #4
djracer
djracer's Avatar
Re: faster time.
what carb and ignition are you running? Have you tried playing with the timing at the track? You would be amazed at what the proper tuning might do for you like Marv was saying. I do my tuning at the track. The only chassis dyno in my area is marginal at best.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-10-2011, 11:41 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
750 Holley vac secondary's elc choke. And mad billet street fire hei. And what would be a good track timing and street timing ?
-00 Saturn 5spd
1/4:13:90
Old 06-11-2011, 01:39 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: faster time.
Dad said keep advancing till it slows down or pings.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-11-2011, 04:15 AM   #7
Super73
Super73's Avatar
Re: faster time.
You can't always hear detonation. Learn to read the plugs!!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-11-2011, 11:02 AM   #8
djracer
djracer's Avatar
Re: faster time.
have you tried bring the secondaries in quicker with the different springs? I like a 650 double pumper for the street/strip rides unless they are really radicle.
Tell us more about the motor itself. How fast is it now?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-11-2011, 11:24 AM   #9
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
400 sbc stock bore. Stock crank. Flat top pistons . 72cc truck cast heads. 1.90 1.50 beehive springs. 1.6 roller rockers. 503/510 lift cam don't know the rest of the cam off the top of my head. edelbrock eps intake. 1 inch plastic 4 hole spracer. Holley 750 vac 2nd. Msd billet street fire hei. Th350 trans-go shift kit. Stock stall from the 305/th350 combo. 3:42 auburn race posi. 10bolt. 235/75/15 tires for now.
It shifts at 5400rpm I don't like to manually shift it since collom shift. Put it in drive and let it do it's thing. Leaving the line at almost 1100 before I start spinnning at the line. Truck hooks pretty well at the track with only 28-30 psi out back.
5/5 drop. Flip in the rear.
-00 Saturn 5spd
1/4:13:90
Old 06-11-2011, 11:31 AM   #10
Marv D
Marv D's Avatar
Re: faster time.
I am going to say the heads are killing you. Is that a set of 882's/ or what?
Old 06-11-2011, 11:43 AM   #11
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
Yes the heads are holding me back on power . I'm suprized it was going this fast with these heads. And yea I'm not sure but I think they are the 882s I have it written down at home
-00 Saturn 5spd
1/4:13:90
Old 06-11-2011, 08:35 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
okay here is the video of the 13.9 run
im looking for the slip
-00 Saturn 5spd
1/4:13:90
Old 06-12-2011, 10:07 AM   #13
jus2qwk
jus2qwk's Avatar
Re: faster time.
did you change to a longer rod. that is the biggest thing you can do from a stock 400 is go to a 5.7 or a 6 inch rod and get rid of that big heavy piston
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 06-12-2011, 01:41 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: faster time.
get a bbc and put a supercharger on it
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-12-2011, 02:22 PM   #15
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
I'm not sure on the Rods I think stock size. Not sure
-00 Saturn 5spd
1/4:13:90
Old 06-12-2011, 03:25 PM   #16
nomrlz
nomrlz's Avatar
Re: faster time.
those are tall heavy tires. you could try a shorter drag radial. also make sure your fronts are at max air pressure. some will even go 5psi over to less rolling resistance. i assume the engine is in good tune. if not, plugs, wires, air cleaner, etc can pick up a tenth or two if old
nomrlz is offline   Reply With Quote
Old 06-12-2011, 03:51 PM   #17
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
All new wires/wire and everything is new. And I have my other set of wheels the back are 315/35/17 but they will not hook worth a ****. But never took them too the track. Backs are kinda bailed
-00 Saturn 5spd
1/4:13:90
Old 06-12-2011, 03:59 PM   #18
Pop's C-10
Pop's C-10's Avatar
Re: faster time.
I read that unhook tha front sway will help in weight transfer & airing up tha tires to 45psi helps cut down on tha rolling resistance..that thing flyin to 882's it..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-12-2011, 04:03 PM   #19
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
Dont have a sway bar. Never came with one. The high psi up front I'll try !
-00 Saturn 5spd
1/4:13:90
Old 06-12-2011, 06:28 PM   #20
fastwillie 696969
~Rest In Peace~
Re: faster time.
remember these are heavy beast
Old 06-13-2011, 11:14 PM   #21
Magnimike1
Re: faster time.
upgraded stall converter, possibly a gear change then stickier tires.
Magnimike1 is offline   Reply With Quote
Old 06-13-2011, 11:21 PM   #22
3r!c84
Badass
3r!c84's Avatar
Re: faster time.
along with heads thats all coming later. just wondering a few things i could try to pick up some lower e/t. im going to the track this wednesday
-00 Saturn 5spd
1/4:13:90
Old 06-14-2011, 02:50 AM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: faster time.
Whatever its worth. I went from 13.50s to 12.teens with gears, tires suspension tuning.
