Old 06-10-2011, 07:38 PM   #1
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Template for Arm Rest Holes 64-66
Was wondering if anyone has a Template for the Arm Rest Holes in the door panels? This if for a 64-66 door panels. Thanks in advance!
LeftCoast32 is offline   Reply With Quote
Old 06-10-2011, 07:42 PM   #2
steverino66
Re: Template for Arm Rest Holes 64-66
here ya go:
http://rmcavoy.freeshell.org/arm_rests.html
steverino66 is offline   Reply With Quote
Old 06-10-2011, 07:43 PM   #3
LeftCoast32
Custom Builder
Thanks, Greatly Appreciated!
Old 06-10-2011, 07:55 PM   #4
steverino66
de nada (I made it a point to thank the guy who actually did the work and posted it online!)
Old 06-14-2011, 08:43 AM   #5
LeftCoast32
Custom Builder
I was working on the door panels and found out the arm rest location is different on the 64 and 66 cabs I have.
I am talking about the square holes in the doors. It is where the threaded square plastic nuts push into the doors for the armrests.
The '66 doors have 2 sets of holes (4 total) to use for 2 different locations. They have the set for the '64 and the '66.
The '64 doors only have 1 set and they are further to the rear of the door by 2 3/8" from the template I used.
I was provided a template that has been floating around (link below). The template was only good for the farthest forward set of holes on the '66 doors.
Make sure to measure the doors before drilling the holes in the door panels. Good thing I had 2 sets of door panels.
Old 06-14-2011, 08:53 AM   #6
kieth
kieth's Avatar
My 65 Chevrolet C10 has arm rests in it. They use 2 bolts to hold them in. My 66 GMC did not have the armrests but had 4 holes in them. I ordered arm rests from LMC and they only have 2 holes and they do not line up with either trucks interior panels holes and they do not look like the original ones in my 65. I am confused ?
kieth is offline   Reply With Quote
Old 06-14-2011, 08:57 AM   #7
LeftCoast32
Custom Builder
Originally Posted by kieth View Post
My 65 Chevrolet C10 has arm rests in it. They use 4 bolts to hold them in. My 66 GMC did not have the armrests but had the same 4 holes in them. I ordered arm rests from LMC and they only have 2 holes and they do not line up with either trucks interior panels. I am confused ?
I am not drilling the new holes in my second set of door panles until I get the armrests in to check first. If needed I just wont run the armrest is all.
The armrest holes on the 1966 doors are 5 15/16" apart, center to center.
The armrest holes in the 1964 doors are 5 7/8" apart, center to center.
Both of my cabs were built in Freemont, CA and both are Chevrolet cabs.
Old 06-14-2011, 12:58 PM   #8
steverino66
Dude, so sorry if the link I provided above led you astray - it worked on mine (drilled all my own holes) and it never occurred to me that any 4-5-6 would vary - ?
Old 06-14-2011, 01:55 PM   #9
Vernski
Just to add to the confusion of things, I think GMC was one to raid parts bins because my 65 has the 55-59 era armrest in it. And only one on the drivers side. When I ordered two the only ones that matched were 55-59, if you order these don't use the template because it won't match your doors.I measured the drivers side and reversed it to the passenger side and all fit right. It might just be that it depends what plant the truck came from what armrest it has in it JMO...Vernski
Vernski is offline   Reply With Quote
Old 06-14-2011, 02:46 PM   #10
steverino66
Yeah, Vernski, sounds about right - that exact kind of corporate parts planning explains the existence of the TH375 trans I inherited with my truck years ago!
Old 06-14-2011, 03:32 PM   #11
LeftCoast32
Custom Builder
Are these the arm rest you used? These are the right spacing for the holes in the doors. Thanks!
http://cgi.ebay.com/ebaymotors/1955-...item19c4613472
Old 06-14-2011, 04:35 PM   #12
Vernski
I got mine from H&H Classic Truck Parts http://www.hhclassic.com/scripts/Par...001&KeyNo=6296
They look the same as the one from ebay....Vernski
Old 06-14-2011, 09:39 PM   #13
LeftCoast32
Custom Builder
Thanks! The Black Deluxe ones are what I will use.
Old 06-15-2011, 01:19 AM   #14
Captainfab
60-66 Nut
The '66 originally used a different arm rest than the '55-'65 as shown here.....
http://www.classicparts.com/1966-68-...ctinfo/19-641/
When I put arm rests on my '66 Suburban, I purchased the early sytle as they were advertised as for up thru '66. This was before I discovered that '66 arm rests were different. I think I like the early arm rests better.
BTW. Classic Parts have the early arm rests for $35.00 each, and the '66-'68 arm rests for $17.00 each.
Old 06-15-2011, 08:47 AM   #15
LeftCoast32
Custom Builder
I think the early arm rests look much better then the '66-'68 too.
Old 06-16-2011, 02:37 PM   #16
kieth
kieth's Avatar
The 2 sets of holes in my 66 gmc measure 5 5/16 top set of holes 5 1/4 bottom set of holes.............go figure.......Kieth
I have a set of counterpart automotive black armrests part #64-56665-bk they measure 5 3/4 center to center.
Old 06-16-2011, 02:46 PM   #17
kieth
kieth's Avatar
Captain Fab
I have the armrest that comes up on your link above at classic parts, the holes center to center are 5 3/4" the holes in my 66 gmc door panels are 5 5/16" no joy.....I guess I could drill a new rear hole......but think I will try and find the older ones. If I can verify the distance between the holes.
thanks to all for the help......Kieth
Old 06-17-2011, 09:48 AM   #18
Muleman100
Muleman100's Avatar
On my 64 I am putting on new arm rests and I bought the plastic inserts that the screws go into from http://www.truckandcarshop.com/
just place the inserts in and attached the arm rests, very easy.
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
