Old 06-10-2011, 08:53 PM   #1
dmartin1
dmartin1's Avatar
no brake lights or left turn signal in rear. help please!!
i have been workin on the truck for a year.(1978 k20).put a manual steering column and a floor shift in....i have no left rear turn signal or brake lights.
even jumpin the juice past the brake light switch i get abseloutly nothing.
my right side turn signal works,but the left side wont, only in the rear.
im getting flashing power on the plug thing on top of the column,but the plug on the firewall has abseloutly nothing..
i need help! please
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 06-10-2011, 10:19 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: no brake lights or left turn signal in rear. help please!!
i just had this problem myself, check the long connecter on your column thats in the middle under the dash, if it isnt plugged in right you get this situation
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-10-2011, 10:23 PM   #3
cue1go
Yes that is the problem. The steering column connection that is just under the dash next to the column. It's really tight in there so it tends to get unplugged a little when you fiddle around under there. It's sounds like you have been fiddlin'.
cue1go is offline   Reply With Quote
Old 06-11-2011, 01:58 AM   #4
dmartin1
dmartin1's Avatar
yea ive been doin a lot of fiddlin.radio new dash stuff etc.
i checked that thing and its all messed up so i cut one off of the old column and spliced it onto this column with butt connecters.everything works great! thanks!
i can finally drive the p.o.s ahha
65 nova
And more
Old 06-11-2011, 02:49 AM   #5
INSIDIOUS '86
I spent days trying the problem out myself on my rig
