Closed Thread
Old 06-10-2011, 09:00 PM   #1
clemdaddy
clemdaddy's Avatar
need tailgate installation tricks
what is the best way to install a tailgate on a fleetside without screwing up fresh paint?
thanks...
clemdaddy is offline
Old 06-10-2011, 11:09 PM   #2
jbgroby
jbgroby's Avatar
Re: need tailgate installation tricks
no tricks, First you need two people one per side carefully hold the pinion/pivot roller in the pocket and then both you you slowly and carefully palce the pivot in the right spot and incert the bolts. trying to do this by yourself will get the paint scratched.
jbgroby is offline
Old 06-11-2011, 12:23 AM   #3
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I just installed mine today. It took 3 people. As long as your bedsides aren't welded to the rear sill and no other crossmembers are attached except at the front it can be done this way . I mounted the trunnions on the bedsides and removed the bolts from one bedside at the rear sill. Then we swung the bedside out installed the TG on the trunnion on the other bedside then swung the loose bedside back in and engauged the trunnion. Put the TG in the up position and tightened the bolts on the rear sill. i also put masking tape on the adjacent areas for a little insurance.
Alan's Classic is offline
Old 06-11-2011, 08:19 AM   #4
clemdaddy
clemdaddy's Avatar
thanks AC... that bed looks great! wish i had installed my gate at this phase. but already welded and braced.
still not really clear about the process but some tape will a good precaution.
grease on the trunnion might help...
seems like it would start at the top of the bedsides and that the strap on the trunnion would fit in the notches and slide down.
gate up or down best? or 3/4 open? has to drop level?
need some help because this is the kind of stuff that murphy wrote his law about. and i'm not feeling all that lucky today.
thanks for any suggestions...
Old 06-11-2011, 02:17 PM   #5
Alan's Classic
I installed mine before paint by myself. I put it in the open position and angled it down and engauged one trunnion that was already bolted in. Then put the trunnion in the other side of the TG and slid it straight down. If it was painted I would have scratched the heck out of it. I really don't have a solution here. Sorry. Maybe someone else has done it.
Old 06-13-2011, 02:59 PM   #6
clemdaddy
clemdaddy's Avatar
well it's over, and i gotta say it went ok... i have never posted a tech thing so bear with me if its for a simple install but if you haven't done this then maybe this will save you some head scratchin'... and paint scratchin'.
Old 06-13-2011, 03:06 PM   #7
clemdaddy
clemdaddy's Avatar
part 2...
Old 06-13-2011, 08:46 PM   #8
Alan's Classic
Thanks for the write up.
Old 10-01-2015, 01:24 PM   #9
1966chevy
1966chevy's Avatar
Great explanation of how to install the tailgate. I will pass it along!!
1966chevy is offline
Old 10-01-2015, 01:34 PM   #10
1966chevy
1966chevy's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 10-01-2015, 03:24 PM   #11
Ronw435
Ronw435's Avatar
I cut two rectangular pieces out of a milk carton and made them to fit the round mounts. Put them in the tail gate and then mounted it. Keeps from scratching the paint and also helps keep them from rattling.
Ronw435 is offline
Old 11-12-2015, 06:52 PM   #12
1966chevy
1966chevy's Avatar
Closed Thread
