06-10-2011, 09:31 PM | #1 |
Is this a good lowering kit???
I want a 3/5 drop and this kit is cheap. I know you get what you pay for so is this a good deal and have everything I need for a 3/5 drop. This is the first time for me to lower a truck. I've only done civics lol. They are a little different. Just let me know if this is a good kit. Here is the link-->
http://www.autopartswarehouse.com/sk...gs+Best+Seller If this is not a good kit please give me some suggestions. Thanks.
1986 GMC Sierra Classic. (2wd swb) 2011 Honda Civic Si Navi. (sedan) |
06-10-2011, 10:39 PM | #2 |
Happy to be here
Re: Is this a good lowering kit???
Western Chassis makes a good product. I would check in the Suspension Marketplace or the Vendor Marketplace and see if our Forum Vendors can get you a better deal.
06-10-2011, 11:15 PM | #3 |
Ok I will check that out. Thanks for your help. I can't wait to drop it though, I tend to be impatient
06-11-2011, 12:53 AM | #4 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-11-2011 at 12:54 AM. |
06-11-2011, 09:48 AM | #5 | |
Yea that's what I was thinking. Thats kinda why I wanted to ask about the kit, because it is quite cheaper than others...
06-11-2011, 10:29 AM | #6 | |
front drop coil, rear pinion angle drop block kit front drop spindle rear drop leaf spring A-arm rear drop coil rear drop shackle and hanger kit rear drop flip kit "C" section kit bump stops carrier-bearing bracket Kits with rear blocks have pinion angle correction to ensure less strain on driveline Definitely call & confirm what's actually included. Also verify the warranty & return policies (get them in writing).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-11-2011 at 10:38 AM. |
06-11-2011, 10:37 AM | #7 | |
06-11-2011, 10:45 AM | #8 | |
We went back out Sunday mid-morning & it was done by 2 or 3pm. We installed spindles, cut the front coils (1/2 coil @ a time), trimmed the lower a-arm lips, & did a rear flip kit. We both know our way around a truck so that helped....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-11-2011 at 10:47 AM. |
06-11-2011, 10:56 AM | #9 | |
Ok thank you for the help. Very Appreciated
06-11-2011, 11:05 AM | #10 |
The suggestions aren't free. You are now in debt & must pay the balance due.... post up some finished pics .
06-11-2011, 11:07 AM | #11 |
will do. Might be a couple weeks though
