Old 06-11-2011, 01:05 AM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
4.5/6 drop kit install time?
hey guys, tomorrow i PLAN to drop my c10, spring/spindles up front and a flip kit out back. what kind of a time frame am i looking at for completion.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 06-11-2011, 01:22 AM   #2
Mikec10
Mikec10's Avatar
Re: 4.5/6 drop kit install time?
If your truck is rusty, atleast 2-4 days, if its rust free, 1-2 days by days i mean 5-8 hours each.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 06-11-2011, 01:26 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
That depends on what tools you have available. With a well equipped shop, I can do it in a day. That said, expect to spend the weekend doing it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-11-2011, 01:37 AM   #4
ProStreet83C10
Drag Racer
i had a buddy tell me 3-4 hrs??
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 01:43 AM   #5
broey
Square
broey's Avatar
If you can, you should take tons of pics and document the steps you take really well, I bet this could help a lot of other guys out there that plan on doing their own drops... like a step by step.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 06-11-2011, 02:04 AM   #6
ProStreet83C10
Drag Racer
ill do what i can for you guys
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 04:13 AM   #7
bbbc10
Diggin The SquareLife
front took me like 3 hrs did rear in a whole day..
bbbc10 is offline   Reply With Quote
Old 06-11-2011, 09:24 AM   #8
ProStreet83C10
Drag Racer
ok, do i need any special tools for anything, does anything require welding and is there anything i need to know before i get started since McGaughys has very LIMITED instructions
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 10:04 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Don't try to break some kind of "speed record" doing your install.
Now is the time to inpsect all the associated parts.
Look at the ball joints and tie tod ends.
Check wheel bearings and brake hoses.
Do it right the first time.
Take your time, and fix anything else that is bad.
Clean up the greasy parts and throw on a coat of paint.
(paint your spindles ahead of time)
Rusty bolts will slow things down also.
(Start spraying the bolts and nuts down, a few days early, with a good penetrating oil, WD-40, PB-Blaster,... etc.)
Keith
Convert to disc brakes.
Old 06-11-2011, 10:34 AM   #10
Mikec10
Mikec10's Avatar
if your swapping hangers, make sure you have a good air chisel so you can take out the rivets
Old 06-11-2011, 10:52 AM   #11
mooseknuckles
mooseknuckles's Avatar
...expect it to take the whole weekend, that way you should heve enough time for the unexpected!
mooseknuckles is offline   Reply With Quote
Old 06-11-2011, 11:24 AM   #12
ProStreet83C10
Drag Racer
well the starter i bought has to be shimmed more before i can drive it anyway so i may just wait a weekend and do it at a shop
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 11:59 AM   #13
ProStreet83C10
Drag Racer
however, on the flip kit, do the new hangers (things that attach to axle under truck) need to be welded to the axle tube? if not do you recc. a guy welds them for secure fit
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 12:04 PM   #14
lolife99
lolife99's Avatar
The flip kit "saddles" do not get welded.
No need to.
Keith
Old 06-11-2011, 12:08 PM   #15
ProStreet83C10
Drag Racer
ok well i was told by 2 people they NEEDED to be welded......what makes it so they dont need it? reasoni ask is because this will be a pro street truck with a big nasty motor in it and i DO NOT want anything moving on me as i do plan to drag race it....a lot
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 01:09 PM   #16
lolife99
lolife99's Avatar
The saddle is "sandwiched" between the original rearend leaf spring saddle,... and the leafspring.
The U-bolts will hold it in place.
Keith
Old 06-11-2011, 01:11 PM   #17
lolife99
lolife99's Avatar
With a big nasty motor you're going to have more trouble with traction and leaf spring wrap than you are with these flip kit saddles.
Keith
Old 06-11-2011, 03:01 PM   #18
lilpoindexter
lilpoindexter's Avatar
The easiest way I found to get the rivets off was grinding an "x" on the head of the rivet, then chiseling it off with an air hammer.
lilpoindexter is offline   Reply With Quote
Old 06-11-2011, 03:27 PM   #19
ProStreet83C10
Drag Racer
Ok guys. First setback. The front hanger bolt that holds the leaf spring in will NOT come out. It turns but won't budge out. Any help/advice on what to do?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-11-2011, 03:28 PM   #20
lilpoindexter
Did you tap on it with a drift slightly smaller than the bolt, with a bfh?
Old 06-11-2011, 03:54 PM   #21
ProStreet83C10
Drag Racer
Yes. We've tried everything available to us. Hammer/punch, bfh/punch, air impact with hammer. Were at a loss aside from cutting bolt.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
