06-11-2011, 09:05 AM | #1 |
Just like to part out trucks!!
will a posi out of a 67 1/2 ton fit in a 71-72 1/2 ton
Will he need the axles too, or any other problems he may have? Thanks for any help, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 06-11-2011 at 09:05 AM. |
06-11-2011, 09:40 AM | #2 | |
Re: will a posi out of a 67 1/2 ton fit in a 71-72 1/2 ton
The differential itself will swap as long as they are both of the same "series" There are different units for the variation of gear ratios.
The axles are a different story though. There is a length issue. The newer axles are longer than the early ones, so that's a no-go. This is not a simple bolt-in procedure though, you really need a pro to do this kind of installation. You can turn your parts into scrap quickly...
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-11-2011, 11:27 AM | #3 |
i would not think it is worth the effort to swap in a 40 year old posi
06-12-2011, 02:24 PM | #4 |
Restoration Virgin!
Randy....as Longhair mentioned, my understanding is that the carrier will swap in, but they need to grab the pinion gear too (ring and pinion gear should stay together), obviously like cdowns says, someone should look both gears over really good too, and replace/ rebuild if possible might as well replace all bearings and seals while they are there too....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-13-2011, 12:56 PM | #5 |
Thanks guys for info, ring gear and pinion is all with it. Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
06-26-2011, 11:39 PM | #6 |
Here ya go Travis
06-26-2011, 11:44 PM | #7 |
Thanks Randy thats what i needed.
