Old 06-11-2011, 10:55 AM   #1
OKGMC4
OKGMC4's Avatar
5.3 won't start, ideas?
Just got to this point and no go. It's an 01 all stock, stand alone harness from a dealer in TX, and an ECM reflashed for street rod use from SpareECM on ebay. The fuel pump powers on but when I crank it doesn't seem to get spark at the plug wires and my noid light shows no pulse at the injectors. I checked and I do have power to the ECM. I've got to be missing something and not sure what? Any ideas appreciated.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-11-2011, 10:26 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 5.3 won't start, ideas?
Did you check both the constant power and the key on power to the ECU? I somehow blew the constant power fuse during my install.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-12-2011, 01:42 AM   #3
ls1nova71
ls1nova71's Avatar
If you have power to the coils and injectors, check your grounds, make sure they're all in place and tight on clean bare metal.
Also make sure that you have power WHILE CRANKING, certain wires on some ignition switches will have power, but loose power while cranking.
ls1nova71 is offline   Reply With Quote
Old 06-12-2011, 08:31 AM   #4
OKGMC4
OKGMC4's Avatar
Don't have a switch yet, just holding the pink wire and the solenoid wire to the battery to see if it will start. Done this in the past with an LT1 and my brother in laws LS7 and it worked to fire up the engine. I do have 12v at the coils, the injectors, and the crank sensor, and swapped in another crank sensor and no change. The plugs for the PCM show to have good power and ground (I went by a pinout chart) The check engine light comes on as it should. I don't have the brake switch wire hooked up but shouldn't need it just to start. I've heard that if it were a VATS problem it should at least try to start, then die. Not sure about the tune but I don't know anyone with a 99-02 5.3 truck that I could try the ECM in. Sarting to feel frustrated and out of options. Probably need a scanner but don't know which one would do any good. Don't want to waste money on a bad scan tool. Surely I'm not the only person to have seen this?
Old 06-12-2011, 08:17 PM   #5
OKGMC4
OKGMC4's Avatar
Just borrowed an AutoXRay scanner and worse news -- "vehicle not communicating with scanner." I double checked all my battery and ignition power wires in the ECM plug and all the ecm ground wires and they are all good, plus I checked for continuity between the serial data wire and the aldl connector and it's good as well. I can't think of any reason why this thing won't fire or talk to a scanner other than a bad ECM. Is that right?
Old 06-15-2011, 10:34 PM   #6
harnalien
TruckincrazY
harnalien's Avatar
I read this two days ago, but didn't catch it. That's what my problem was. I was losing power during cranking! Got it fired up early this afternoon!!
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 06-15-2011, 11:11 PM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Harnalien, did you get your truck on the road yet?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-15-2011, 11:28 PM   #8
harnalien
TruckincrazY
harnalien's Avatar
Not yet, just got it started today! It's been an eventful few months, so I've only been able to work on it here and there. Hopefully I'll be rolling by this weekend. Gotta put the tranny cable on and clean up. This thing sounds like a BEAST!!!
Old 06-20-2011, 06:46 PM   #9
OKGMC4
OKGMC4's Avatar
Sent my ECM off to the guy who sold it to / programmed it for me. He said there was a catastrophic failure. It wouldn't talk to the software in his laptop either. Asked me if I rewired the harness myself and I told him no, I used a harness from a guy in Texas who goes by techrods on ebay. The ecm guy says they are good harnesses, he was afraid I did it myself and crossed some wires. Anyhow, he's setting up a new computer and shipping it back to me under the 1 year warranty so if I'm lucky I may still be able to hear this thing run this week!
Old 06-20-2011, 07:49 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Catastrophic failure of an ecm isn't the most common, unless something happend somewhere down the line. I've seen an ecm fry/fail when a battery died during uploading a tune, although never just had one "go bad". I've had "code gremlins" on other gm's so I wouldn't rule it out.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-24-2011, 06:41 PM   #11
OKGMC4
OKGMC4's Avatar
I got the ecm today and plugged it in and it fired off almost immediately. I won't run for more than 3-6 seconds and sometimes it sounds good and sometimes it sounds rough. The engine hasn't run in 4 or 5 years so I'm thinking clogged injectors maybe. I'm just tickled that it works and that the ecm was the problem. I've got some more trouble shooting to do...
Old 06-25-2011, 11:14 PM   #12
OKGMC4
OKGMC4's Avatar
Spent a lot of time cleaning gooey clogged injectors and it runs GREAT! Starts right up, louder than hell with no exhaust. My neighbors hate me now...
Old 06-26-2011, 02:06 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
mine too, that just means your doing it right!
