Steering column help
Greetings,
1972 Blazer with manual trans and no tilt. Decided to replace the aftermarket steering wheel with a stock one. Used a puller with no issues to remove. Upon removal; i can feel the exposed part of the steering shaft moving form side to side, about a 1/4" or so. Replace with stock wheel and play is still there; turn sig and horn work. As I start to go for a drive and turn the wheel I can hear the horn activating as the wheel moves side to side. Is there a exploded view of a stock column somewhere? Is there a bearing up top that I trashed in pulling the non-stock wheel? Any ideas appreciated. Thanks, Tony |
Re: Steering column help:update
Update:
Found the top bearing trashed. Does anyone have a Manufacturer or P/N for a .75" ID x 1.25" OD .250 thick bearing. No Joy from local part stores. Thanks, Tony |
