Old 06-11-2011, 12:45 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
85 Shock mounting questions
On our trucks the shocks are mounted 1 in front and 1 behind the rear end. Is there any drawback to mounting them both behind the rear end?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-11-2011, 03:31 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 85 Shock mounting questions
Mine are both forward...
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-11-2011, 03:41 PM   #3
softballnrd27
Maybe I am thinking of my 4wd I used to have.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-11-2011, 04:09 PM   #4
bluex
bluex's Avatar
My driver side is on the back side of the axle and the passenger side is on the front...
Edit, my '78, the '87 4wd K5 and the '77 2wd K5 frame are all this way.
bluex is offline   Reply With Quote
Old 06-12-2011, 02:06 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
gm did that to counter act wheel hop
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-12-2011, 10:48 AM   #6
Keith Seymore
Keith Seymore's Avatar
This is correct. To counter act both wheel hop and wheel tramp:
Hop - both wheels going up and down at the same time
and
Wheel Tramp - rear wheels going up and down alternately.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-12-2011, 02:50 PM   #7
softballnrd27
With caltracs and a flip kit, will mounting both shocks in front of or behind the rear pose any major problems?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-12-2011, 06:25 PM   #8
INSIDIOUS '86
well the caltracs keep the spring from forming that S shape that will cause your wheels to unload and cause wheel hop. so I imagine with the caltrac switching the shocks will yield a more consistant launch that is both most likely straighter and level.
just make sure you have your pinion angle set corectly and you should be rather happy with the setup.
try asking some of the guys in the suspension forum they would prob be more qualified to give you the info you seek.
