carb/intake manifold match up
So, I put a 2" carb spacer on, with new gaskets, and things weren't lining up like I feel they should.
![]() And the carb is the Edelbrock 1406 ![]() Is this supposed to be like this?
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic. Last edited by willstruck; 06-11-2011 at 04:44 PM. |
The One And Only !!!
Re: carb/intake manifold match up
Looks like your trying to put a square bore carb on a spread bore intake, That takes a different spacer/adapter something like this; http://www.summitracing.com/parts/EDL-2696/
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Yep, you need an adapter, not a spacer. The spreadbore intake you have is built for a q-jet style carb with small primaries and large secondaries. The squarebore carb will never seal up right on the spreadbore intake w/o the adapter plate.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
That was kinda my thought, but the intake manifold and carb. are both Edelbrock Performer. From their site I got the impression that they were supposed to go together. The site lists the manifold as a dual plane.
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic. |
It is a dual plane intake. Notice the divider between the left and right banks. It is just a spreadbore intake, not a squarebore like your carb is. Two different animals altogether. The easy solution is just to get the adapter restrorob linked to above. A few different people make them, and you can usually source a Mr. Gasket version at your local parts store.
Gotcha. Thought it was either spreadbore or dual plane. Now I get it. I've seen the adapters at the store, I'll pick one up.
Get the 4 holer and not the open plenum adapter.
FYI, $26 through summit, $44 at O'Reilly's... gonna order it, but I figure I'll order new jets/rods whatever. I have the Edelbrock 1406, which is for fuel economy (came with the truck) but I want more power. Gotta figure out what I should get..
