06-11-2011, 07:50 PM | #1 |
Senior Enthusiast
LMC Polyvinyl floor mat
Has anybody ever purchased the LMC Polyvinyl floor mat?
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=60 If anyone installed one of these, does it: Cover the entire floor (and how far up the firewall does it go)? Fit well? Look good? Is it worth the money? |
06-11-2011, 09:39 PM | #2 |
Re: LMC Polyvinyl floor mat
Mark, I THINK mine is original (decent shape, but pretty crusty) - but it looks like the LMC one goes up the firewall the same amount - if you look closely at the picture, the little semi-slot on the driver side on the right side of the top cutout (just above the little hole) is where the clutch linkage goes DOWN through the firewall. OR - the little cutout in the top/front of the driver side is for where the braces for the dash support/steering column attach to the firewall. Either way, it's about the same amount - so, if I'm looking at it right, there is about an inch or so of rubber above the hole where either the clutch linkage goes through the floor or the dash braces mount to the firewall. It's not as high up the firewall as I'd like it to be - but the LMC one looks to be go about as far up as the stock one.
06-12-2011, 12:30 PM | #3 | |
Mark, I purchased a aftermarket rubber floor mat that is full length of the cab, it goes all the way from the top of the firewall to the back of the cab. It has a pebbly texture and does not look exactly stock but I really like it since it allowed me to dynamat and insulate the entire floor for noise and heat , and makes it easy to clean up. But for the life of me I cannot find the reciept for where I got it. Kieth found it www.raybuck.com Kieth Last edited by kieth; 06-13-2011 at 12:10 PM. Reason: add link |
