Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 06-11-2011, 10:42 PM   #1
48cj2a
48cj2a's Avatar
Parting out a complete GM J code 6.2 Diesel 48000 miles
Heads complete w/ injectors, less rocker arms and shafts, missing one GP - $200.00
Rear Vacuum Pump with mounting bracket and bolt - $45 shipped
Valve covers - $20
Front Cover, waterpump, all hardware - $20
IP with gear- $200
Intake with bolts (non EGR type) - $45
Exhaust Manifolds - $25
Pushrods - $20
Crank - $25 (crated in plywood box 28 1/4" x 8 1/4" x 8 1/4" 83lbs)
7 Pistons and 8 rods - $25
Camshaft and lifters - $25
Starter Front Support Bracket - $7 (SOLD)
Rocker Arms and Shafts - $40 (SOLD)
Oil Pan - $25 (SOLD)
IP lines - $50 (SOLD)
Oil Lines - $40 (SOLD)
Fuel Filter Assbly - $35 (SOLD)
Air Clearner - $25 - (SOLD)
Air Cleaner Resonator - $25 - (SOLD)
Pictures upon request
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline
Old 08-02-2011, 05:29 PM   #2
rockmanben
Re: Parting out a complete GM J code 6.2 Diesel 48000 miles
do you have the vavume pump from the 6.2?
rockmanben is offline
Old 08-02-2011, 08:28 PM   #3
48cj2a
48cj2a's Avatar
Yes if you are talking about the one at the rear were a distributor would typically go.
$45 shipped anywhere in the USA.
03 Suburban Z71 Z71
48cj2a is offline
Old 08-06-2011, 10:10 PM   #4
OnDaTrail
OnDaTrail's Avatar
What year is the engine? Mainly asking to see if your valve covers are late enough to have the CDR on top of the passenger side valve cover as opposed to being on top of the valve cover.
1983 GMC Sierra K2500- The Rat
1986 Chevrolet Silverado C10- The Donor
The DD: 1999 Chevy S10- 4.3 Vortec, 5 speed, Ext Cab
OnDaTrail is offline
Old 08-06-2011, 10:42 PM   #5
48cj2a
48cj2a's Avatar
This is a 85 CUCV (Blazer). The CDR was on a bracket going to both sides of the intake and the oil fill tube not the valve cover so they are both solid covers (no holes for emissions). I transferred the CDR system to my replacement motor which had the CDR out front by the alternator and also have that system available as seen in the bottom picture.
03 Suburban Z71 Z71
48cj2a is offline
Old 08-08-2011, 06:13 PM   #6
48cj2a
48cj2a's Avatar
Never heard back guys Vacuum Pump and Valve Covers are still available.
Lowered a few prices...
03 Suburban Z71 Z71
48cj2a is offline
Old 08-11-2011, 08:29 PM   #7
48cj2a
48cj2a's Avatar
Crank and all bearings look very good as do the all rods and pistons except #6.
Crank is crated in plywood box with front and rear journals supported by plywood too. 28 1/4" x 8 1/4' x 8 1/4", 83lbs.
03 Suburban Z71 Z71
48cj2a is offline
Old 08-16-2011, 12:26 PM   #8
48cj2a
48cj2a's Avatar
Crank, Pistons & Rods, Cam & Lifters all available - decided he does not want them now.
03 Suburban Z71 Z71
48cj2a is offline
Closed Thread
