Old 06-12-2011, 01:00 AM   #1
67chevy1series
67chevy1series's Avatar
oh my brake problems.......
well today i was going to bleed my brakes for the first time... took the prop valve off bleed the air out of the master cylinder... after that i started with the back brakes ot those done moved to the front and its leaking in between the brass block and the caliper... what do i do?
heres the statistics:
new:
calipers
pads
all the hard lines
rear wheels cylinders
brake shoes
old:
drums
rotors
and the fronts and rear rubber hoses, all of these items are perfect nothing wrong no need for replace.
for those that are having a hard time figuring out what i am talkin about heres a diagram:
67chevy1series is offline   Reply With Quote
Old 06-12-2011, 02:08 AM   #2
Jeffs70
Jeffs70's Avatar
Re: oh my brake problems.......
first i would take it off and make sure both sides of the block are cleaned from any dirt or anything that can cause it to leak. and also make sure nothing is plugging it up. also to make sure you have the washer that belongs on the bolt and make sure its tight thats all i can think of.
Jeffs70 is offline   Reply With Quote
Old 06-12-2011, 02:15 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Also double check that there's only one of those washers per side. They will often stick to the hose side and people will not notice it is there and install another one.
If this checks out OK, and the above recomendations fail, then replace the washers.
Old 06-12-2011, 02:18 AM   #4
67chevy1series
the washers are good the areas that meet arent contaminated and the calpers are brand new and the hoses are clear because there letting fluid through and then out through the leak...thanks for the fast responses. i really apprciate it guys
Old 06-12-2011, 04:39 AM   #5
cdowns
cdowns's Avatar
those washers on the banjo bolt fittings sshould b replaced with new ones// they are crush washers and many times leak when reused
they are cheap and can b found in the "help" section of the autoparts stores
Old 06-12-2011, 06:16 AM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i concour
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-12-2011, 08:36 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
.. with cdowns and fastwillie, replace the copper washers on the fitting.
LockDoc
Leon
Old 06-12-2011, 10:30 AM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
yup
John
1999 Toyota Tacoma 4x4
Old 06-12-2011, 11:03 AM   #9
68gmsee
Active Member
68gmsee's Avatar
And yup!
If everything is new and clean, there are no imperfections and you are torquing them down correctly, then that's the only thing left.
68gmsee is offline   Reply With Quote
Old 06-12-2011, 11:26 AM   #10
tooter
tooter's Avatar
Even if they are new that where I would start..
tooter is offline   Reply With Quote
Old 06-13-2011, 12:45 AM   #11
Jeffs70
Jeffs70's Avatar
I totally agree also.
Old 06-13-2011, 12:50 AM   #12
67chevy1series
well i found the problem... the new claipers have a raised wall, then it dips in for the hole instead of being flat, the new brake hoses are a circular end instead of a square so... it cant get on the hole to seal.. i have a quick fix ( i know quick fix doesnt sound good because im working with brakes but it wont defect it can only help..)
Old 06-13-2011, 12:54 AM   #13
Jeffs70
Jeffs70's Avatar
thats good to hear its not something that can not be fixed. did you purchase this all as a set brand new? if so I would contact the people you purchased it from and they should replace the hose to match the set.
Old 06-14-2011, 01:19 PM   #14
67chevy1series
no the hoses came off my frame when i got it but my frame wasnt used for 12 years or so and before that the guy who had it i believe it got in a frontend crash and they bent the front frame horns and the first crossmember, but they straightened it and bolted in a new crossmember and redid the shocks and all the brakes and ball joints... the ball joints where bad because we sand blasted the frame... the chocks are still good still have them and the brakeshoses are perfect! so they were are the ones made like GM made and now they have this new S#!tty style that sucks... so cant return the brakes hoses
