Old 06-12-2011, 09:40 AM   #1
68handmedown
Steering problems
Had a ram assist and steering box was shot so i removed and noticed the center link is totaly different than power and manual steering center link. Went to junk yard and got a center link off of a 70 c-10 and a manual steering box off a 68 C-10. Removed center link and everything connected to it. Set the new center link in the truck and bolted the new box in. all went together pretty easy. Only one problem the pitman arm on the steering box seems to be to long and will not bolt in the center link. I assume there is different size pitman arms and why would there be a lenght difference? Both parts are from a manual steering set up. Truck has been sitting for 8 months and im tired of seeing her sit. Please help my truck is depending on you.
68handmedown is offline   Reply With Quote
Old 06-16-2011, 08:48 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Steering problems
Do you have any pics of your set-up?
Keith
Convert to disc brakes.
Old 06-16-2011, 09:06 AM   #3
68handmedown
So i pulled all back apart and started at the pitman and everything bolts right up. Kind of scared to drive because alignment was eyeballed so im hoping it does not pitch me off the road. Any ideas to get it as close as possible? I have heard about measuring the front of tires then the back to make sure its close but anything else i should do?
Old 06-21-2011, 05:22 PM   #4
Dano69c10
Dano69c10's Avatar
The pitman arms are different for powers teering and manual steering.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
