Old 06-12-2011, 11:43 AM   #1
Fesser
Fesser's Avatar
Pertronics Distributor wiring
I am using a Pertronics distributor and their flamethrower coil. This setup doesn't have points but still uses an external coil (unlike HEI). The instructions say not to use a resistor wire to the coil. DO I simply do the same mod as the HEI installation discussed here?
http://67-72chevytrucks.com/vboard/s...=resistor+wire
Secondly, Do I keep the yellow wire that is connected to the starter (the one that is removed for the HEI install)?
I frequently try to wire things myself which often seems to let the magic smoke out of the wires. Then nothing works right. Thanks for any help. Frank
Fesser is offline   Reply With Quote
Old 06-12-2011, 12:38 PM   #2
hchad18
hchad18's Avatar
Re: Pertronics Distributor wiring
Bypass the resistor wire to the coil and don't use the yellow wire going to the starter. It was used to send 12 volts to the points during startup
hchad18 is offline   Reply With Quote
Old 06-12-2011, 01:59 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's the wiring diagram for the pertronix ignition with the stock coil and the flamethrower ignitor coil. The ballast resistor is used here for the older vehicles but the newer ones use the resistance wire that comes from the firewall block. Just bypass the wire by using a wire from the ignition unfused terminal on the fuse panel. Yeah you won't need the yellow wire anymore.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-12-2011, 04:07 PM   #4
Fesser
Fesser's Avatar
Unbelievably good help! Thanks guys. Frank
