Old 04-01-2003, 12:50 AM   #1
70cst10
Popping out of gear
Hey guys, what's up? Well, I've had a little problem lately. My truck (68 c10 with a 3 on the tree) has started popping out of gear into neutral on the interstate at higher speeds lately. Any ideas of what this could be? I suspect the shifter fork or something. I don't really have much experience with manual transmissions and I have very little time to fix/diagnose the problem (being in the military), so I'd like an idea of what could be wrong before I start digging. Thanks!
Milan
1964 Chevelle SS 283/M20
70cst10 is offline   Reply With Quote
Old 04-01-2003, 01:29 AM   #2
Joachim
Carolina Cajun
Re: Popping out of gear
Originally posted by 70cst10
...this is more fun than a barrel of beer . . .
Seems to me that you have held on to the wires too long.
My 68/L6 seems to do the same thing, only from second to neutral. On the steering column just after it comes out of the firewall, is a pair crescent shaped spacers with a nib inbetween. Ultimately these work the shift linkage to the transmission. The nib is worn down, and or the bushing(s) that keep these spacers/nib in alignment is worn. Supposed to be a "fix kit" for it. I'll be looking at the Food Lion Auto Fair this weekend (Apr 3,4,5&6) Charlotte NC. Will keep in touch if I find what we need.
(formaly: RM2)
USS Lexington/USS Little Rock
Joe
The Carolina Cajun, almost famous in North Carolina since 1989!
Driving a 68 & Restoring a 66.
Lookin' for Rochester Manual 1bbl & 2bbl carbs!!
Concord, NC & Ponchatoula, LA
Joachim is offline   Reply With Quote
Old 04-01-2003, 01:54 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
normally when they pop out of direct, it's a misalignment problem. Possibly the input shaft has worn the pilot bushing or the input bearing is getting bad.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-01-2003, 02:36 AM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Here's a stab in the dark - it could be low on fluid. Probably not if it hasn't been leaking...but my girlfriend's Opel started doing it about halfway home from Santa Monica to Phoenix...it ended up the tranny leaked like a sieve and had almost no gear oil in it! Filling it up and sealing it off has almost completely fixed it (almost, since running it that far with that little had to have done some damage...)
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-01-2003, 07:55 PM   #5
70cst10
Those little pieces are pretty worn down on my linkage as well. I have to hold the shifter toward my chest when I go to neutral from first or reverse or won't shift. I don't think I've ever seen a replacement piece for that though..
Milan
Old 04-01-2003, 08:36 PM   #6
SCOTI
SCOTI's Avatar
If you figure this out let me know as this just started happening to me as well on a recent road trip. Below or @ 60 is no prob . . ....but get over 65 & it started coming out of gear pretty often. VERY annoying.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-02-2003, 12:24 AM   #7
jhow66
jhow66's Avatar
Worn synchronizers--teeth on gear and synchronizer rings are rounded --only way to fix is replace.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-05-2003, 06:44 PM   #8
70cst10
It's just as well, I guess. I want to put a muncie m20 in it anyway. Is there anything I should look for? I have a 250I6 in the truck now, but I'll be swapping to a sbc or maybe a big block soon. How do I know which tranny to buy? Is the swap difficult?
Milan
Old 04-05-2003, 10:29 PM   #9
Class of 69
Class of 69's Avatar
Since you have a 3 speed now, going to a 4 speed is very easy. The trans will bolt right in. You just need to make a hole in the floor for the shifter. The input shaft on an M20 will have two grooves around it, the M21 has one. The output shaft on both of these will be the same size, and spine count as the 3 speed, therfeore the yoke on the drive shaft will interchange. There are some 1st gear ratio differences between them.. the m20 has a lower gear ratio in first giving you a wider spread between 1st, and 2nd .. the m21 has the same percentage of ratio change between all gears, and are some times called close ratio muncies
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-05-2003, 10:43 PM   #10
alta-aj
Nope,
chances are that if you go to a 4 spped you have to change the hump cover to a high one and possibly replace the carpet.
alta-aj is offline   Reply With Quote
