Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-12-2011, 12:28 PM   #1
eagle43ca
2002 jimmy s serries
cant find fuse or circut breakers for power seats
eagle43ca is offline   Reply With Quote
Old 06-12-2011, 07:11 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: 2002 jimmy s serries
Drivers side of dash in the drivers door jam. Pull the little cover off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-12-2011, 07:34 PM   #3
eagle43ca
thank you i have looked in there as well as under the hood and still can not find any breakers or fuses for power seats switchs are good i ran a live wire to the and they work ok stumped on this
Old 06-13-2011, 12:41 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: 2002 jimmy s serries
Google searched.
Left side of the dash, to the right of the IP fuse block. Its a 25 amp circuit breaker, an aluminum cased breaker. CHECK FOR POWER ON THE SEAT SWITCH "A" TERMINAL AND GROUND ON THE "D" TERMINAL. IF YOU HAVE POWER AND GROUND THE SWITCH IS BAD.
