Old 06-12-2011, 03:44 PM   #1
63 Chevy Stepside
Cab Insulation Question
What solutions have you guys used behind the open areas in the upper cab corners for insulation of sound? Is there any reason not to put something up there? Thanks.
63 Chevy Stepside is offline   Reply With Quote
Old 06-12-2011, 04:46 PM   #2
A.T. RockDriller
A.T. RockDriller's Avatar
Re: Cab Insulation Question
63step..
If you are convinced that you have absolutely no leaks of any kind up there, then I can't see why a fella couldn't use some of that spray foam.
In fact.....now that you got me thinkin', I'll be doin' just that.
That's a great way to deal with the noise.....plus some extra "R" value for the hot/cold issues.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 06-12-2011, 05:13 PM   #3
Max1775
Max1775's Avatar
I was considering that myself when I get to that point. I would imagine that making sure it was leak free would be paramount. I guess you could also stuff it with fiberglass or foam. At least ot would be removable.
Max1775 is offline   Reply With Quote
Old 06-12-2011, 09:14 PM   #4
63 Chevy Stepside
The spray in foam is what I was thinking. I was wondering about doing a liner of some sort, plastic or something, so that it wouldn't get wet if it did leak. The area in mine is in good shape rust wise, so I don't think I have any leaks. I do know that my cab is loud and anything I can do to hush it up a little I would like to do.
Old 06-12-2011, 11:26 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Anyone considering spray foam might want to take a look at this thread first:
http://67-72chevytrucks.com/vboard/s...ght=spray+foam
Old 06-12-2011, 11:49 PM   #6
A.T. RockDriller
Well now,........That makes it easy.
Sure don't need any self-inflicted head-aches.
Les Hunter
Old 06-13-2011, 09:58 AM   #7
kieth
kieth's Avatar
I just updated this thread, I decided against the spray in foam, I am spraying sound dampening undercoating into the recessed areas of my cab in an attempt to keep the noise down.....without attracting rust. Kieth
kieth is offline   Reply With Quote
Old 06-13-2011, 11:09 AM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Cab Insulation Question
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-13-2011, 11:24 AM   #9
kieth
kieth's Avatar
I used home depot roof repair material for the sound deadening material ($ 1.25 sq ft) and then added air duct insulation over that about the same $1.25 sq ft. this really quieted the cab down. The question asked in this thread was about those areas that you cannot get to (top back wall, roof, etc. in the cab. I just sprayed as much sound deadener / undercoating as I could get into the roof and back of the cab. trying to quieten it down, still does not do much for the insulation but it did help.
Old 06-13-2011, 04:12 PM   #10
63 Chevy Stepside
Thanks for the replies and the links, very interesting. I don't think I will be doing any of the spray foam, just the sound deading sprays and maybe a loud stereo
Old 06-13-2011, 04:40 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
careful use of "RIGHT STUF" and an empty plastic jar make for a very cool hidden compartment, should you need one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-13-2011, 07:56 PM   #12
Max1775
Max1775's Avatar
Now we know. Thanks for the link Mark.
Old 06-14-2011, 01:47 AM   #13
PrerunnerRob
PrerunnerRob's Avatar
Line-X. Kills sound and completely bonds to whatever it touches if properly prepped.
PrerunnerRob is offline   Reply With Quote
