Old 06-12-2011, 03:48 PM   #1
DT1
DT1's Avatar
Hood to Cowel Weather Seal
I replaced my hood to cowl seal when I painted the truck and now the hood rides up a bit too high. I know it's because of the harder than usual durometer
of the rubber. I got this one from LMC and as usual, it's a second rate part. Does anyone know if a softer one is available and whom might have one?
Thanks!
DT1 is offline   Reply With Quote
Old 06-12-2011, 04:01 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Hood to Cowel Weather Seal
I got mine for my '72 GMC from Wes at Classic Heartbeat. Fits great... It seems fairly pliable.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-12-2011, 04:28 PM   #3
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Classic parts for mine, they all push the hood up when new, I resolved mine by undoing the hinge bolts at the fender and really pushing down hard at the back on each hinge and retightening to make sure the hood was pulled down as far as it could go.
Not to be a smart ass or anything, have you installed it correctly?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-12-2011, 06:52 PM   #4
AirSpeed
AirSpeed's Avatar
I bought one from LMC and Classic parts, they were identical. I couldn't get mine to close without forcing the hood up, I even tried adjusting the hinges with no luck, they both went in the trash. I thought about putting some foam weather stripping in there instead but never bothered, I couldn't find a reason to go to the trouble unless I was looking for a perfect showroom truck.
I haven't had any issues, have any of you had a problem without the seal?
AirSpeed is offline   Reply With Quote
Old 06-12-2011, 07:00 PM   #5
john
member #16
john's Avatar
The lmc seals are 90 degree angles like eightbangers. The original are more of a < angle and do not hold the hood up.
john is offline   Reply With Quote
