Old 06-12-2011, 06:13 PM   #1
harveyrc2003
Schrader valves
Going to run bags but want to run Schrader valves. To I get more money for rest of set up. So need help how should I run it an can I see pics of how u ran it thanks guys for ur help.
harveyrc2003 is offline   Reply With Quote
Old 06-12-2011, 10:16 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Schrader valves
I don't have any pics, but its pretty straight forward. Run a separate line from each bag, and a valve for each bag. That will allow you to fill them independently and prevent air transfer from side to side.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-12-2011, 10:59 PM   #3
harveyrc2003
Re: Schrader valves
Ok where would I hide fill up point ride tech said back bumper thats the pic I need to see. So I have an I deal thank you for ur help will run separate.
Old 06-12-2011, 11:45 PM   #4
SCOTI
SCOTI's Avatar
Re: Schrader valves
If you don't want them visible.... then yes, you need to 'hide' them.
I mounted the rears on my 68 behind the license plate. The left side bag was mounted on the left; the right side on the right. If/when I needed more spring rate to pull the trailer, I flipped the LP up & added air.
My 74 also had/has an AOL set-up. There were some holes drilled into the bed floor in front of the wheel tubs by the previous owner that I used for the schraders. Since they were right up against the bed wall (in front of the tubs), you didn't really notice the valve stem cap poking out the floor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-12-2011, 11:58 PM   #5
harveyrc2003
Re: Schrader valves
Old 06-12-2011, 11:59 PM   #6
harveyrc2003
Re: Schrader valves
Thank you for the help.
Old 06-13-2011, 05:44 AM   #7
S10Fan
Old Heap Driver
Re: Schrader valves
Just keep in mind that if you develop a leak, even a very slow leak (and you will), you could end up with no air source and a bottomed out truck.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-13-2011, 10:50 AM   #8
SCOTI
SCOTI's Avatar
Re: Schrader valves
Route lines away from heat; route them away from any source of chafing, & bubble check your fittings before installation. I do mine this way & haven't had issues.
That being said, I would not utilize schraders on the front of a street driven vehicle.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-13-2011, 12:54 PM   #9
S10Fan
Old Heap Driver
Re: Schrader valves
Ditto
Bryan
