Old 06-12-2011, 08:52 PM   #1
jerry moss
Born Psycho
jerry moss's Avatar
Question ford dana 60 questions/14 bolt ff
i know i can't use it under anything i own since it's a driver side drop BUT a friend wants to trade his ford 60 and GM 14 bolt full floater for a 14 bolt semi floater i have. i know it sounds like a no brainer trade but the 60 is a ball joint axle and is missing the driver side knuckle, spindle, tie rod, hub and rotor. i talked with a neighbor that builds rock crawlers and he said the ball joint version is not as desireable as the kingpin version and is probably the "metric 60" which uses the ford only hub-centric wheels. i have no use for any of this stuff but thought i might be able to make a few bucks off it since guys converting late model GM trucks need the driver side drop. i'll ask you 4x4 experts--what would you do if offered this trade?
the 60 has 3:73 gears and the 14 bolt ff is unknown at this time as it's still under the 3/4 ton truck.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-13-2011, 12:40 AM   #2
Davidmichael
Davidmichael's Avatar
Re: ford dana 60 questions/14 bolt ff
Your neighbor is right. People do not want that axle. Around my area, people just scrap that kind of axle. The 14bff is a good deal though. Around my area they go for $100 to $400 depending on options.
Why would the guy trade a FF for a semi floater? But do the trade if your SF is stock and you don't have a ton of cash into it. Try to sell the 60 if you can and keep/sell the FF.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 06-13-2011, 09:38 AM   #3
jerry moss
Born Psycho
jerry moss's Avatar
thanks for the reply. my SF is stock, 4:10 gears and oem limited slip/posi. i'm sure his FF is stock also, original 74 chevy 2wd, 3/4 ton. he wants my SF so it won't have the hub sticking out in the center of the wheel.
jerry moss
Old 06-13-2011, 09:44 AM   #4
I would think with all the people who go "Ga Ga" when they hear "Dana60" that someone would snatch it up. It may not be the most desirable version,but it still is the big boy compared to other axles. Maybe it's not a $1,000 axles,but surely 1/2 that. And,what about people who own trucks that axle belongs in? Not everybody is a rockcrawler,especially not 88-98 guys who just want a tougher truck.
Old 06-13-2011, 09:56 AM   #5
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: ford dana 60 questions/14 bolt ff
Tim,
i thought about the late model GM guys wanting to lose the indepentent stuff. as i said above , i have no use for any of it- both my 72's have 14 bolt FF rears in them now. if the 60 was a passenger side drop, i'd modify it to fit one of my 72's just so i could say it's got a "60". i'll probably do the trade and see what happens as far as selling it off.
jerry moss
Old 06-13-2011, 10:25 AM   #6
70 beast
Certified Hobbiest
70 beast's Avatar
Ive seen balljoint 60s go for around $500 in nor cal so im sure someone would want it.
They may be mostly undesirable but their not totally useless.
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 06-15-2011, 04:16 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I say go for it. I no its not the top dog of the ford axles but I am sure you could probably get a couple hundred bucks out of it. Plus the Full Floater is way better then the semi floater so I see it as a bonus all the way around. Good luck
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-16-2011, 10:44 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
thanks to everyone for your input. we are supposed to do the swap this weekend. as i said before, i don't need/want any of this stuff so it'll be for sale in the near future. i'll post a for sale ad when i have the stuff in my yard.
jerry moss
