Old 06-12-2011, 10:38 PM   #1
BigRed76
BigRed76's Avatar
Where can I get a proportioning valve?
I recently diagnosed a bad proportioning valve on my '76 and have been searching the internet for a new one (since part stores say they can't get one), and the only prop. valves I can find are for GM cars. Does anyone know where I can get a new proportioning valve for our trucks??
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-12-2011, 11:47 PM   #2
SCOTI
SCOTI's Avatar
Re: Where can I get a proportioning valve?
Inline Tubing has exact replacements in brass or aluminum.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-13-2011, 12:12 AM   #3
BigRed76
BigRed76's Avatar
I did not see any replacement proportioning valves in thier catalog for any GM trucks newer than '70.
Zach
Old 06-13-2011, 12:28 AM   #4
SCOTI
SCOTI's Avatar
http://www.inlinetube.com/Prop%20Valves/VCT104.htm
http://www.inlinetube.com/Prop%20Valves/VCT105.htm
http://www.inlinetube.com/Prop%20Valves/VCT103.htm
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-13-2011, 12:35 AM   #5
BigRed76
BigRed76's Avatar
Thank you for the links. They do not specify, but do you know if theres a difference between 2wd and 4wd?
Zach
Old 06-13-2011, 11:05 AM   #6
SCOTI
SCOTI's Avatar
I don't believe so. From what I can tell, the design is based on disc/drum or disc/disc applications. I would give them a call for specifics to be sure.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-13-2011, 11:34 AM   #7
Pyrotechnic
Pyrotechnic's Avatar
Years ago I was able to get one from a parts shop that dealt with AC Delco brand parts. The usual chain auto parts stores didn't have the valve at that time either.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 06-13-2011, 02:46 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
Google dans classics in Portland Oregon. I just bought one from for $60 about two months ago. He had it sitting on the shelf. It was made by cpp
Old 06-13-2011, 03:15 PM   #9
SCOTI
SCOTI's Avatar
Is it the adjustable unit? If so, it's not a direct swap. Brake line fittings are sized differently in a couple of ports.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-13-2011, 11:33 PM   #10
BigRed76
BigRed76's Avatar
Thats what I noticed about the CPP prop valves for GMs. They have the 3/8s threads for the two front lines which fits the cars, but not the trucks.
Zach
Old 06-14-2011, 12:06 AM   #11
Corts60
Just here to tinker
Corts60's Avatar
Nope, it was a direct replacement; solid brass. All I did was call him and ask for a proportioning valve for a 1978 chevy 1/2 ton. Bolted right up.
