Old 06-12-2011, 10:38 PM   #1
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Cracked Brake Line Fix
Went to change the oil in the truck today and noticed something I have missed for the last 5 years. The brake line that runs from the rear of the proportioning valve down to a flare union at the crossmember under the engine, was rubbing on my header. Not good. So I gently moved it out of the way and "boink" it cracked at the weak spot where it had been rubbing.
So I hop in the '94 and off to the parts store for some fittings and a 4 foot piece of 1/4" steel tubing.
Here are a few pics of the process. I bent some of it by hand just to get it around things. But the two 90 degree bends I did with the tubing bender. First 2 pics are of the culprit. Third pic is the new line I bent. I even removed the "slinky" from off of the old tubing and reinstalled it on the new tubing. I'm assuming its to help keep it from rubbing the frame and the other tubing for the front brakes. Fourth and fifth pics are of the tube installed in the truck. Vacuum bled the brakes and good as new!
I relocated the holding tab on the frame a little further up to help keep the vibes down and keep them in place. Very happy I found this in the driveway and not on the highway!
I am soooooo glad I bought a quality tubing bender and a flare double flare tool as well.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-12-2011, 11:44 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Cracked Brake Line Fix
Good Job! Brakes can be handy.
ETsC10 is offline   Reply With Quote
Old 06-12-2011, 11:51 PM   #3
70cst
70cst's Avatar
Impressive work
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-13-2011, 09:30 AM   #4
bollybib
bollybib's Avatar
Good job on the brake line. They can be challenging to fabricate and install.
I found a brake line contacting a header pipe, too. The line looks OK (no obvious wear, surprisingly) but it was another item in a list of issues that made me decide to get rid of the headers and go back to ramshorns.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 06-13-2011, 01:21 PM   #5
GASoline71
GASoline71's Avatar
Thanks you'se guys.
Gary
