Old 04-01-2003, 04:10 AM   #1
MSL
MSL's Avatar
Question Rear end.
Ok the thing i have on my mind is how do you find out what gear ratio is in the rear end. in my truck it will not burn or chirp the tires it just goes. so what do i need to do to find out what im running. it seems its like it was geared more for hauling.
MSL is offline   Reply With Quote
Old 04-01-2003, 04:39 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Best way is to take the rear cover off and count the teeth of the ring and the pinion. Divide the smaller into the larger to get your rear axle ratio. This is a good time to clean out the old fluid and replace the gasket. You need to also make sure of no shavings in the grease. More than likely if the engine and tranny are in good shape then the rear axle may be a high gear ratio like mine 3.07. This is more for highway driving and not the get off the line fast ratio.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-01-2003, 05:01 AM   #3
MSL
MSL's Avatar
Hey thanks im pretty sure im running that same ratio. my engine and tranny seem in really good shape it will launch when i hammer it but it doesnt break loose i guess thats a good thing somewhat.lol But ya i will get the cover off and find out what i got and replace and clean things.
Old 04-01-2003, 06:58 PM   #4
Ol' Grey
A work in progress
Ol' Grey's Avatar
Check the RPO sheet in the glove box. Mine is GU4, but I swapped in a 12-bolt rear. I identified it as a 3.08 as well by the metal tag on the housing.
Code:
RPO    1st yr    lst yr      desc.
GU1      76          87       AXLE,RR 2.41 RATIO
GU2      76          88       AXLE,RR 2.73 RATIO
GU3      82          85       AXLE.AR 2.93 RATIO
GU4      76          88       AXLE,RR 3.08 RATIO
GU5      76          88       AXLE,RR 3.23 RATIO
GU6      76          88       AXLE,RR 3.42 RATIO
GV4       82         87       AXLE,RR 3.36 RATIO
GV8       82         85       AXLE,RR 2.72 RATIO
GW4      84         85       AXLE,RR 3.31 RATIO
GW6      85         88       AXLE,RR 3.27 RATIO
GW9      76         88       AXLE,RR 2.93 RATIO
GX3       82         88       AXLE,FRT 3.33 RATIO
GX4       76         83       AXLE,RR 3.75 RATIO
GX5       76         83       AXLE,RR 4.09 RATIO
GY5       76         87       AXLE,FRT 3.65 RATIO
G44       85         87       AXLE,RR 3.07 RATIO
Ol' Grey is offline   Reply With Quote
Old 04-01-2003, 07:51 PM   #5
MSL
MSL's Avatar
I dont have that in my glove box i have something that shows codes but nothing about the rear end.
Old 04-01-2003, 10:21 PM   #6
apstguy
LED King
apstguy's Avatar
Most likely if it doesn't have the code, it is 2.75 or whatever the common stock one was. I have the 3.08 and my truck does the same thing. Doesn't break loose unless there is water or corner.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 04-01-2003, 10:23 PM   #7
Mike76251
1GQ1 RPO
Anyone know what a 1GQ1 rear ratio might be for a '84 Silverado 10 bolt?
Mike76251 is offline   Reply With Quote
Old 04-01-2003, 10:58 PM   #8
Ol' Grey
A work in progress
Ol' Grey's Avatar
Re: 1GQ1 RPO
GQ1 is standard ratio, open carrier. Most likely 2.73
Old 04-01-2003, 11:06 PM   #9
1FaastC10
1FaastC10's Avatar
heh, my C10 had 3.08s in it, and i couldnt keep the tires from spinning. wierd...
1FaastC10 is offline   Reply With Quote
Old 04-01-2003, 11:30 PM   #10
Mike76251
Re: Re: 1GQ1 RPO
Ol' Grey,
Thank you very much.
That explains why this thing only does 1700rpm at 55mph.
Old 04-02-2003, 01:32 AM   #11
1FaastC10
1FaastC10's Avatar
oh yeah, that's a 2.73 allright!
Old 04-02-2003, 02:37 AM   #12
Lil Greg
If you don"t feel like counting teeth www.nastyz28.com has gear ratios just by looking on the staped numbers on the gear teeth for example 41-11 = a 3.73 rear end.
Lil Greg is offline   Reply With Quote
Old 04-02-2003, 02:38 AM   #13
MSL
MSL's Avatar
Thanks for the site.
