Old 06-13-2011, 12:11 AM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
My 1983 Chevy C10's BRAND NEW look!!!!!
ok guys, i spend from noon to 10:30 pm Saturday, minus a 2 hr break and about 1 hr this morning doing a FULL drop kit on my truck. I used a Mcgaughys 4.5" front/6" rear drop kit. It consisted of spindles and springs up front as well as a flip kit out back. I still have to install shocks and do some other minor stuff before i can drive it, but its fine as im waiting on a shim for my starter anyway. Heres some pics of it finished. If anyone wants any kind of write up/how to pics i will do those in another thread.
Before:
After:
Sitting on Bump Stops - removed and not much change, probably will end up needing to C-Notch it
for some reason this tire is MUCH closer to fender lip than other front tire, not sure if this is alignment issue alone or if i need to go back in and check stuff, i can BARELY get my fingers between tire and fender whereas left front i can fit fingers in there plus extra room
Well guys, let me know what you all think of the outcome and any suggestions on that right front tire being so different from the other three would be awesome, i know i still need to istall all 4 shocks, but i doubt thatll change this issue any. also, my buddy says since i lowered it factory alignment specs are incorrect and i need new specs that fit new parts. is this true or not.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 06-13-2011, 12:14 AM   #2
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: My 1983 Chevy C10's BRAND NEW look!!!!!
Sweet!!!! that made the whole truck, she's pretty
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-13-2011, 12:22 AM   #3
lilpoindexter
lilpoindexter's Avatar
You should have chiseled off the rear bump stop bracket to give more clearance...then you just drill a little hole in the frame, and put in one of those little mushroom shaped bumpstops.
It's going to be more difficult to remove now that it's dropped, but not impossible
lilpoindexter is offline   Reply With Quote
Old 06-13-2011, 12:29 AM   #4
SBTork
Garage wrench
SBTork's Avatar
looks a TON better
Good job
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 06-13-2011, 01:28 AM   #5
bluex
bluex's Avatar
Truck looks good!
Go ahead and save for some 255/60 front tires. You will not be able to run those 275 for long on the front. I had them on mine and after I dropped it any little bump or dip in the road at speed and the fenders were chewing the sidewalls up. I only did the 2.5" spindles and it was eating my tires bad.
bluex is offline   Reply With Quote
Old 06-13-2011, 02:52 AM   #6
Pop's C-10
Pop's C-10's Avatar
perfect stance
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-13-2011, 03:14 AM   #7
my4by2
my4by2's Avatar
Agreed - stance it's perfect just the way it sits!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 06-13-2011, 03:51 AM   #8
bbbc10
Diggin The SquareLife
u nailed it! jus need a sport bumper!! an remove hitch..
bbbc10 is offline   Reply With Quote
Old 06-13-2011, 07:29 AM   #9
baclay9
Looks awesome man. Since you changed springs you will definately need an alignment by the way.
baclay9 is offline   Reply With Quote
Old 06-13-2011, 07:46 AM   #10
ProStreet83C10
Drag Racer
hey guys thanks, hitch is already removed and anyone have any suggestions about the front tire issue i psted up? is that ALL alignment or is something else goofy with it?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-13-2011, 09:29 AM   #11
96twodoor
96twodoor's Avatar
I had the same problem with my 84 except the drivers side was lower than the passanger side.Its drove me nuts to the point where I took it back apart to ensure the coils the seated properly (which they were).I ended up chocking it up to just a simple chevy lean and the lowering made it much more noticeable. I ended up using the little trailer coil spring spacers that they sell at auto stores to level it and it aligned just fine. So you not alone. haha
96twodoor is offline   Reply With Quote
Old 06-13-2011, 09:34 AM   #12
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
Exactly my thoughts. Looks great!!!
West Texas Z is offline   Reply With Quote
Old 06-13-2011, 10:12 AM   #13
jimboh247
jimboh247's Avatar
That is exactly yhe stance I want for my truck, if and when I decide to lower it!
There was a thread similar to this earlier in the week. Same situation.
Look up Keith Seymore's recent posts. He gives a description of how the body/front end is put on at the factory. He also points to why one side could be closer to the tire than the other.
He does an infinitely better job describing the situation.
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 06-13-2011, 10:26 AM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Nice! Now time for a rear bumper...
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-13-2011, 03:37 PM   #15
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Sweet looking good turned out great nice job I have no experience with lowered trucks really so I got no input good luck.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-13-2011, 03:42 PM   #16
silvereagle07
silvereagle07's Avatar
Looks nice ! I'm lovin the red paint and the slots.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-13-2011, 04:07 PM   #17
moneyeater
moneyeater's Avatar
The look is absolutely cool!
I have that "Chevy Lean" at the rear right corner and i heard that it is quite common to our style trucks!
I like your waist jewelery!
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 06-13-2011, 05:38 PM   #18
bigwheel15
bigwheel15's Avatar
The truck looks much happier now!
bigwheel15 is offline   Reply With Quote
Old 06-13-2011, 06:31 PM   #19
mooseknuckles
mooseknuckles's Avatar
nice clean truck man!.....mine had the same prob with one side lower than the other, apparently its quite common....you should get rid of the rear bumpstop completely, and unless you haul crap in the back or hit a huge bump it shouldnt bottom out!...I never had a c-notch or pipe notch for a long time.
mooseknuckles is offline   Reply With Quote
Old 06-13-2011, 07:56 PM   #20
BusinessProfessor
Great looking truck! I really like that red.
BusinessProfessor is offline   Reply With Quote
Old 06-13-2011, 11:19 PM   #21
ProStreet83C10
Drag Racer
rubber bump stops are out but bump stop "bracket" is still in place, both front corners are same height, just one tire is closer to fender lip than other. Hitch is already off and will be ordering sport bumper this weekend from LMC.
thanks for all the comments guys!!!!! Keep em comin!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-14-2011, 01:59 AM   #22
96twodoor
96twodoor's Avatar
Oh I see , sounds a little different than the problem I was having, I would like to see Keith seymours post on that , but anyway truck looks great and the bumper will just set it off
Old 06-14-2011, 03:31 AM   #23
mtjasper
mtjasper's Avatar
Damn I've seen the same thread on 3 different forums now Truck looks great!
-Mt Jasper
1998 GMC Suburban 2500 4x4~6.5
1987 Chevy K10 RCLB 4x4~6.2 81,000 Original Miles
1982 Chevy K10 RCLB 4x4~6.2
1983 Chevy C10 RCLB 2x4~6.2 1 Million Miles
FERN MEADOWS REGISTERED SIMMENTAL CATTLE
mtjasper is offline   Reply With Quote
Old 06-14-2011, 08:01 AM   #24
ProStreet83C10
Drag Racer
yup i get around...watch out!
anyway, anyone know if these shocks are supposed to have dust boots on them or not. they currently do NOT have any dust boot, just the hydraulic cylinder. Let me know.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-14-2011, 03:37 PM   #25
Squareforceone
Squareforceone's Avatar
my favorite part is the iowa plates im up in ottumwa
Squareforceone is offline   Reply With Quote
