Old 06-13-2011, 12:59 AM   #1
elks
Help ID Diff...
1970 Chevy PU long bed. I think a 3/4 ton. supposedly a stock diff. It has a large round rear cover with 10 bolts, but seemed way heavier duty than a 10 bolt. Had drum brakes, but the contact surface was pretty thin left to right. The fron of the diif and rear both unbolted to access pumpkin.
I have pics on my phone, but no way to get to computer. It so had 456 gears.
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 06-13-2011, 02:04 AM   #2
TrkEnvy
Re: Help ID Diff...
Its either a eaton HO52 if its a C20 or a HO72 if its a C30. If you dont mind the low gear its not a bad rear. But if you want fuel econ then your gonna have to ditch it. They never made a gear taller than 4.10 for it.
TrkEnvy is offline   Reply With Quote
Old 06-13-2011, 11:10 PM   #3
elks
Re: Help ID Diff...
It looked really strong. How good of an axle is it? I am not sure if I want it, but I am looking for a strong set of 1 ton axles for my blazer. SOme research shows a 14 bolt detroit locker will fit it.
Old 06-14-2011, 01:05 AM   #4
TrkEnvy
Re: Help ID Diff...
I wasnt aware that a 14 bolt carrier would fit it. Makes me a bit skeptical, but my dad has one in his '66 C20 and he is ditching it for a 14 bolt. They can be picked up for a song in junkyards cuz GM made so many and parts are cheap for em. In my opinion the Eaton rears arent bad, but its old tech. GM used them from '47-'72 so its definately dated.
Old 06-14-2011, 09:23 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Help ID Diff...
your worn drums are not avalible.... except from junk yards and places like this site that parts out old trucks.
If it is a 3/4 ton (coil springs maybe?) then it is an HO52, the HO72 (dam near the exact same thing) was only under c/30 trucks.
it is a tough rock solid rear. but parts are getting hard to find.
Old 06-14-2011, 01:40 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Help ID Diff...
Somewhere on the top of the axle housing, usually the right side, there will be a series of letters/numbers stamped on that tube. If you can read those, there's a way to decipher specifically what it is, ratio, etc., and I think you can also narrow the year down to one or two, in the translation.
Member Nr. 2770
Old 06-14-2011, 07:42 PM   #7
bosco200
bosco200's Avatar
Re: Help ID Diff...
You got a HO-52 my friend...I got the same rear end in my C20 with 4.57's....The rear end is a HOSS....if you want a good rear end Id stick with it ....but yes if you keep the 4.57's in the gas mileage will not be the best...I get around 8...and im pushing around 4,000 RPM at 55 mph.
bosco200 is offline   Reply With Quote
Old 06-14-2011, 10:47 PM   #8
gmebey
Re: Help ID Diff...
Look at the front of rear end, if it has a bolt/lock nut on the driver side it is a H072.
They made some C20 with 1-ton rear ends, which I think they called "supper"....correct me I'm wrong here.
gmebey is offline   Reply With Quote
