4l80e/4l60e
Guys, I was just wondering. I currently have a 6.0 with a 4L80E. The transmission seems to have a converter whine. It has the correct amount of transmission fluid. Anyways, I have access to a 2500 stall converter for a 4L60E. Can I use it in my 4L80E? Just wondering!!
meowMEOWmeowMEOW
Re: 4l80e/4l60e
The 80E uses 6 bolts to the flywheel, I believe the 60e does not.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 4l80e/4l60e
What he said^^^^^^
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: 4l80e/4l60e
Not trying to be a smart _ _ _, but I am aware of that. Are the both of you saying that it wont bolt to the flexplate.
Re: 4l80e/4l60e
4L60E & 4L80E converters do not interchange. I would like to know more about this whine, Does it only happen in 1st gear? All the time?
![]() Join Date: Dec 2007
Re: 4l80e/4l60e
^^^Agreed. Get that whine figured out before you are replacing more than a converter..............
Re: 4l80e/4l60e
The whine is consistent throughout each change of the gears. The whine was rather loud at one point when I first did the the new engine start up. Now that I am driving the vehicle and of course checking vehicle fluids daily, the whine is not as loud but is present It actually sounds like a real quiet gear drive, but it is definitely coming from the converter. My truck is somewhat sluggish aslo.
meowMEOWmeowMEOW
Re: 4l80e/4l60e
any problems with lock up?
Re: 4l80e/4l60e
I do feel the tranny lock up. But, it slips in and out of lock up. Currently, the truck is being driven in town, so a lot of stopping and starting. It just really drives like I have a stall converter and it is just the original converter that came with the 4L80E.
#10 | |
Re: 4l80e/4l60e
The converter could be bad, BUT a bad converter can & will damage the transmission. Take it to a transmission shop & have them do a line pressure test in reverse should be at least over 250psi, If not its rebuild time.....How many miles are on your trans? 4L80Es do fail. They are VERY stout transmissions, but they dont last forever. |
Re: 4l80e/4l60e
I, for one, am glad guys like clinebarger take the time to answer posts to help folks out. I'll say it in case someone forgets...THANKS!
Re: 4l80e/4l60e
Clinebarger, I am very appreciable to your answer about the tranny. I do plan on having the tranny tested as you said. I will keep you posted on the outcome.
#13 |
Re: 4l80e/4l60e
Chris, you rock!
i'll send a check Monday..JK
#14 | ||
Re: 4l80e/4l60e
I dont take Rubber Checks! ![]() |
#15 |
Re: 4l80e/4l60e
awwwww Man, that hurt dude, hurt real deep too......
