Old 06-13-2011, 04:20 PM   #1
POPO1984
POPO1984's Avatar
Door repair panels
What is everyones opinion on the inner door repair panels. I need to replace them on both of my doors and was just about to order them from a vendor.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 06-13-2011, 04:45 PM   #2
rob32472
Re: Door repair panels
unless they have been revised then they suck..... be prepared to hack them up and only use what you need...
rob32472 is offline   Reply With Quote
Old 06-13-2011, 05:41 PM   #3
Fastfun
Fastfun's Avatar
I didnt have any problem with the ones that I installed. I bought them from Brothers.
Fastfun is offline   Reply With Quote
Old 06-13-2011, 07:22 PM   #4
mbgmike
Overall the fit is usally fine on the Taiwan made stuff with the exception that the stamped lines on the inner side do not line up well with the factory lines. they are off bad. Assuming that the part is not defective like large wrinkles or crushed sections which can cause problems. Most of the time they aren't but they do happen. You can reshape them some but its a lot of work after paying for the part. We sell an american made inner but I have never installed that particular part so I can't say if it lines up better. Here again if you can find a damaged door with a good bottom you are better off. Are they worthless, not by any means but they do have issues.
mbgmike is offline   Reply With Quote
Old 06-13-2011, 09:03 PM   #5
fishingjred73
fishingjred73's Avatar
How much do the American inners cost and how tall are they?
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 06-13-2011, 09:19 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
i had a lower inner and outer installed on my door from classic parts of america. He said that they went on pretty good.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-14-2011, 12:00 AM   #7
POPO1984
POPO1984's Avatar
Well Mike ill probably be getting with you in the next few weeks and get them from you I got mine blasted and primed and got a few spots to fix
South Houston
Old 06-14-2011, 12:23 AM   #8
72lb4x4
I'd think you could find a pair of doors that don't need too much work. I had a pair that weren't too bad I was barely able to give away not too long ago.
I snagged a set from Pick-n-Pull a few years ago from a 71. One had a big shallow dent and a bullet hole (I found the slug) but minimal rust.
72lb4x4 is offline   Reply With Quote
Old 06-14-2011, 09:18 AM   #9
POPO1984
POPO1984's Avatar
If i find a cheap set of good 72 doors i will probably get them but if not im gonna try and repair them myself.
South Houston
Old 06-14-2011, 09:19 PM   #10
mbgmike
they are 11" tall. I will have to check on the cost from the MFG. Its been a while since i purchased any
Old 06-14-2011, 09:22 PM   #11
mbgmike
like always we will refund if you don't like the fit.
