Old 06-13-2011, 05:40 PM   #1
AirSpeed
AirSpeed's Avatar
Tie rod ends and front end alignment
Last week I was looking for a noise coming out of my front end, I jacked up the front end and shook the crap out of everything, everything was tight and the only thing I could find that could be making the noise was the upper leaf spring bushing. Today I replaced the bushings and the noise it now gone but I found that both tie rod ends were VERY worn and very sloppy. I can't figure out how they could be so sloppy after just a few days!
Anyway, I ordered new ones, they will be here tomorrow and now I'm curious what I can do to keep the front end aligned when I replace the tie rod ends on my other truck I remember spinning the wheels while holding a piece of chalk against the tread, drawing a line all the way around then measuring the line, making sure I end up with the same measurements after I install the new ends. I can't get time to have the front end aligned at a shop for at least a week. Are there any other methods I could use to get the alignment very close? Thanks! Aaron.
AirSpeed is offline   Reply With Quote
Old 06-13-2011, 06:16 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Tie rod ends and front end alignment
Marking a line on the tire and measuring front & back is the way to go, about a 1/8 toe in, done right and you shouldn't need to go to the alignment shop.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-13-2011, 08:38 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I measure the distance from zerk fitting on the inner, to the zerk fitting to the outer, then make the new one the same length.
Old 06-14-2011, 02:59 AM   #4
AirSpeed
AirSpeed's Avatar
Thanks guys! I will try a combination of both!
Old 06-14-2011, 09:37 AM   #5
68gmsee
Active Member
68gmsee's Avatar
And you could also try the counting the threads method by counting how many revolutions it takes to remove it. I always lose count.
68gmsee is offline   Reply With Quote
Old 06-14-2011, 09:43 AM   #6
85_C10_Sleeper
85_C10_Sleeper's Avatar
i run 1/16 " of tow on 30's But thats just me. I wouldnt run anymore than 1/4 on a normal size tire. and i would do 1/16 at the least.
And as far as method goes, i scribe the tires and get a buddy to help me measure it. make sure your accurate were you measure! First time i did it my friend kept moving the measuring tape up and down every measurement!
85 C10 LWB
305ci - 700r4 - 10 bolt - 3:08 gears
Collecting parts for a 'mild prerunner"
85_C10_Sleeper is offline   Reply With Quote
