Old 06-13-2011, 06:43 PM   #1
hoopty-cuztom
hoopty-cuztom's Avatar
i need engine id help please
i pulled the engine out of the blazer its a 454. from what i know this was a new gm crate engine put in the truck i think around mid 80's. im am tryin to figure out for sure what it is so when i order part for this truck i can order the right parts,
now in front of the pass side head where it would have a # there is nothing i dont know if thats how it works on a crate engine or what.
on the back of the block i got a # 14015445
on the head i got # 14081045
i cant find an exact match for either of those numbers.
and if yall could tell me what year truck to get parts for that would fit this engine as gaskets and such that would be great
thanks for lookin
edit: pics
hoopty-cuztom is offline   Reply With Quote
Old 06-14-2011, 09:32 AM   #2
Burt4x4
Burt4x4's Avatar
Re: i need engine id help please
The Power of Google
Number Size Rated Horsepower Production Main Caps
340220 427 1968-1976 Four-bolt (tall-deck)
346236 454 1975 Two-bolt
361959 454 1978-1987 Two-bolt or four-bolt
364776 427 1974-1976 Four-bolt (tall-deck)
364776 454 1977-1990 Four-bolt (tall-deck)
364779 366 1968-1990 Four-bolt (tall-deck)
473478 427 1977-1990 Four-bolt (tall-deck)
1014183 366 1991-1992 Four-bolt (tall-deck)
3855961 396 325 and 360 1966 Two-bolt
3855962 396 360, 375, and 425 1965-1066 Two-bolt or four-bolt
3869942 427 390 and 425 1966 Two-bolt or four-bolt
3873858 396 375 1966 Four-bolt
3902406 396 325, 350, and 375 1967 Two-bolt or four-bolt
3904351 427 425 1967 Four-bolt
3916321 427 425 and 435 1968 Four-bolt
3916323 396 325, 350, and 375 1968 Two-bolt or four-bolt
3935439 427 435 1968 and 1969 Four-bolt
3935440 396 350 and 375 1969 Two-bolt or four-bolt
3937724 366 1968-1976 Four-bolt (tall-deck)
3955272 396 325, 350, and 375 1969 Two-bolt or four-bolt
3955272 402 325, 350, and 375 1969 Two-bolt or four-bolt
3955274 366 1968-1976 Four-bolt (tall-deck)
3955276 427 1968-1973 Four-bolt (tall-deck)
3963512 454 360, 375, 425, and 460 1968-1971 Two-bolt or four-bolt
3969852 366 1968-1976 Four-bolt (tall-deck)
3969854 402 360 and 375 1972 Two-bolt
3969854 454 360 and 375 1972 Two-bolt
3969858 427 1968-1973 Four-bolt (tall-deck)
3999289 454 1972-1979 Two-bolt
3999290 402 240 1972 Two-bolt
3999293 366 1968-1976 Four-bolt (tall-deck)
3999294 427 1968-1973 Four-bolt (tall-deck)
10114182 454 1992 Four-bolt (tall-deck)
10114184 427 1991-1992 Two-bolt or four-bolt
14015445 454 1978-1987 Two-bolt or four-bolt
Here is the webpage I found...
http://www.roadsters.com/bbc/
Not sure how accurate this is as my 454 is a 361959 and should be a 73-85 454 yet this site says it's 78-87 so??
I found another site that has your head #
http://www.minuit10.net/EngineCode/c...linderHead.htm
Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-14-2011, 03:54 PM   #3
hoopty-cuztom
thank you, i did the google search and could not come up with anything, i figured someone on here would know or could find it
so if i go to my parts store and order a gasket set for a 79 c20 with a 454 that will work for this engine right,
sorry im new to the chevy, my 77 ford blew up in 08 and now my 95 dodge is falling apart so imma try the chevy next
Old 06-14-2011, 04:54 PM   #4
47thriftmaster
47thriftmaster's Avatar
Engine block 1405445 = 1975-1987 454ci for light duty truck
For the head the closest I could come up with is - open chambered/oval port head for a 454, but the years not sure says 1986-1990. Not really sure on the head but you can always call GM to check the numbers.
47thriftmaster is offline   Reply With Quote
