Old 06-13-2011, 10:25 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Rebuilding front/rear suspension/brakes
I want to rebuild the suspension/brakes on my 85 when I get back from Af-hell-istan and would like my list scrubbed for anything I missed.
Front:
Poly Graphite front end rebuild kit from P-S-T:
2 Upper Ball Joints
2 Lower Ball Joints
2 Outer Tie Rods
4 Polygraphite Control Arm Bushings
2 Upper Control Arm Bumpers
2 Lower Control Arm Bumpers
Cpp 2.5" Drop Spindles
Coil Springs(Moroso Trick)
Rancho 9000 adj shocks
New Rotors w/D52 caliper kit
Wheel bearings
CPP Manual brake Master Cylinder/Proportioning Valve
Rear:
Disassemble, clean, and reassemble leaf packs
Polygraphite leaf/shackle bushings
Install rebuilt ford 9" with axle perches for a flip
Wilwood Dyna lite rear Disc Brake kit
Rancho 9000 Adj shocks (relocated in front of the axle)
Cal Tracs
Universal Splined Sway bar kit from S&W
I am looking for a good ride that will perform well on the street and strip. If there is anything else I missed or you suggest I do please let me know.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-14-2011, 12:20 AM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Rebuilding front/rear suspension/brakes
Are the steering box, idler and pitman arms tight?
lilpoindexter is offline   Reply With Quote
Old 06-14-2011, 01:41 AM   #3
bluex
bluex's Avatar
Pick up a set of solid tie rod adjusters like these:
http://www.google.com/products/catal...d=0CFAQ8wIwAA#
bluex is offline   Reply With Quote
Old 06-14-2011, 12:06 PM   #4
softballnrd27
I will have to check that when I get home. The steering didn't seem sloppy at all from what I remember.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-14-2011, 12:47 PM   #5
softballnrd27
Are drilled and slotted rotors worth the extra $$?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
