Old 06-13-2011, 10:45 PM   #1
grs
vent window handle kit.
Are LMC's vent window handle kits any good? Will they last a long time? And are they hard to install?
grs is offline   Reply With Quote
Old 06-14-2011, 09:12 AM   #2
blakeduren
Re: vent window handle kit.
I have been happy with them. Purchased several years back, holding up well.
blakeduren is offline   Reply With Quote
Old 06-14-2011, 11:41 AM   #3
grs
How easy are they to install?
Old 06-14-2011, 04:44 PM   #4
blakeduren
Pretty straight forward once you get into it. It has a good exploded diagram that comes with it. Several gasket options included for different years of truck. I think I remember the roll pin they send is really long and they tell you to cut it to length, but I think I just used the stock one in it's place. Also, I like to use some loc-tite on the main center bolt holding the non-handle part together.
Old 06-14-2011, 06:38 PM   #5
grs
Someone caulked the left vent window shut. He had 2 pennies on the latch to keep it tight. I got it open, and the vent window works, so I will order a handle kit. I also have to buy a very small punch.
Old 06-15-2011, 01:34 PM   #6
kevinr1970
I did mine a few years back but don't remember anything too difficult.
For $14 (at least at the time I bought the kit), it was worth it to cut out the wind noise, even if they only last a few years?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 06-15-2011, 08:03 PM   #7
grs
I bought a handle kit from LMC. Mey have it Friday.
Old 06-17-2011, 05:48 PM   #8
grs
I got my handle kit from LMC today. The instructions say parts in package A are is used in certain years, and parts in the bag marked B are used in certain years. All the parts are in one bag that is not marked A or B. I guess I just have to be careful when I take the old one apart to see what parts I need to use. I will also call LMC, and ask them. Just thought I would let you know.
Old 06-18-2011, 08:53 AM   #9
blakeduren
I think it is just the thickness of glass used...
you will figure it out.
Old 06-18-2011, 01:24 PM   #10
grs
I agree. If the glass is thicker I believe I should use the thinner rubber. I got the left one fixed . I then used the incorrect rubber pieces on the other one. I think it will work too. It is just a little loose.
