Old 06-14-2011, 12:27 AM   #1
CamaroChris
Gas tank questions
is a 1986 suburban gas tank same as 87-91 gas tank? I am trying to find a way to do the fuel system. I think the best wrought is to get a gas tank from an 87-91 'burb because it already came with a fuel pump? I would change to a 255lph of course. so will the sending unit out of a 87+ 'burb fit into my 86 fuel tank? Thanks In advance
CamaroChris is offline   Reply With Quote
Old 06-15-2011, 01:27 AM   #2
CamaroChris
Re: Gas tank questions
Please help I have been searching everywhere with no luck
Old 06-15-2011, 07:22 AM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
No they are not the same.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-15-2011, 09:57 AM   #4
Jonboy
Slots go on anything!
I am pretty sure they will physically interchange, but the 87-up tanks are baffled for fuel injection.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-15-2011, 11:37 AM   #5
RandyP
RandyP's Avatar
Exactly, and if you're going to be running the pump in the tank, you need that.
Old 06-16-2011, 03:11 AM   #6
CamaroChris
what If I were to fill the tank with that foam that keeps the gas from sloshing around? http://www.summitracing.com/parts/SUM-290190/
I could also build a baffle around the sending unit like the F-bodys?
