Old 06-14-2011, 12:38 AM   #1
C10CORIE
C10CORIE's Avatar
My next 2 bumps in the road.............
I have a Hydro Boost P/S Pump......................Can I just block off the top spout on the side of the pump?
Its a return line I believe, so it SHOULD be next to no pressure while running................no??
The next thing is,what do you connect that front cross over pipe to?
Its the small pipe that connects to the front of the heads.
Trying to get this thing road worthy for the puyallup and spokane good guys shows.
Thanks in advance.
C10CORIE is offline   Reply With Quote
Old 06-14-2011, 06:09 AM   #2
67C10BUB
67C10BUB's Avatar
Re: My next 2 bumps in the road.............
The pipe on the front of your heads is most likely your steam vent. You will want to run that to a high point in your coolant line. Some drill and tap their water pump and run it there, but I just ran it to a spare port on my radiator.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 06-14-2011, 07:13 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Hydro boost pumps have one pressure and two returns. You can plug a return with no problems.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-14-2011, 09:25 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
for the steam vent, here is an option if you dont want to drill and tap the WP.
http://www.jagsthatrun.com/Pages/Par...plice-Kit.html
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-14-2011, 11:00 AM   #5
Shon
I T-d in my 2 lines on the hydraboost pump, works well. just have to get a resevior (sp).
I have a self contained unit that eventually I will put on the truck when I have time...
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-16-2011, 10:45 PM   #6
ls1nova71
ls1nova71's Avatar
Thanks in advance.
Not to hijack your thread, but I have a question. Are you not running the hydroboost? It sounds like you are not, and if so, are you running a vacuum power brake booster, or no booster at all? The reason I ask is I'm looking for the plug that goes in the back of the intake on a hydroboost truck, and have the fitting for the power brake vacuum hose, and wanted to see if you were interested in trading?
ls1nova71 is offline   Reply With Quote
