Old 06-14-2011, 11:50 AM   #1
72tutone
Removal of outer rear window steel
Guys, I am getting ready to replace my rear window with a solid piece, and my super has the stainless trim that goes around the lower side of the window.
Is there an easy way to remove this piece?
Also when I install the new rubber seal do I need to put anything on the outside of it? Adhesive or anything?
72tutone is offline   Reply With Quote
Old 06-14-2011, 11:54 AM   #2
steelhorse
steelhorse's Avatar
Re: Removal of outer rear window steel
Cut the seal with a razor from the inside and once it is out it should be easy to remove.
steelhorse is offline   Reply With Quote
