Old 06-14-2011, 01:54 PM   #1
eastcoastcivil
Question Will 72 C30 front disc brakes work on a 67 C20?
I have the opportunity to buy a 72 C30 parts truck with disc brake set up and was wondering if I would have a hard time to swap the disc set up to my 67 C20? What all is involved I guess is what I am asking.
If your not living for something, your dieing for nothing...
eastcoastcivil is offline   Reply With Quote
Old 06-14-2011, 03:51 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Will 72 C30 front disc brakes work on a 67 C20?
if it is a single rear wheel type front end, then go for it.
If it is a daul rear wheel, then the hub/rotor isn't the same, and I'm not sure if the spindle would be the same size or not.
Old 06-16-2011, 05:30 PM   #3
eastcoastcivil
So this is it..... Think it will work?
Old 06-17-2011, 06:44 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The conversion is the same as a normal half ton conversion, just bigger. You can swap the entire suspension, or just control arms and brake stuff just like you'd do on a smaller truck.
Old 06-17-2011, 06:56 PM   #5
Beat68CST
Beat68CST's Avatar
You'd just unbolt the whole front crossmember and bolt it right back on your 3/4 ton.
Should be cake.
Beat68CST is offline   Reply With Quote
